PULSERs ONLY
Started by Grumpy, December 18, 2006, 10:36:27 AM
Thaelin
   Notice that you got very little movement from the wire? Size and length of the wire makes for a fair amount of resistance. Try that with larger wire and you will see more movement due to the increase in the amps used. It directly relates .  Try that with two strands of lamp wire and you will see what I mean.
sugra
weggl
 Have not worked out how to post on this site yet, maybe someone could tell me how.
so i am posting this as a reply which is not a reply.
Hi guys, I am rather new to this hydrogen stuff, I am a 68-year-old bloke in Sydney Australia. I have been fooling around with a plate system with the idea of using it as a boost system on a Toyota Corolla. I was not happy with the output as it required too many amps, so I have built a unit that is a Joe cell configuration comprising of a 1?, 2?, 3?, and 4?, 5? and 6? outer, all internal cells are 8?high with the 6? -12? high, 4 of the cylinders are neutral.
I am currently producing (water displacement test) 0.5 l/min at 18 amps and 21deg c
My question is would this amount of gas be sufficient for my purpose?
I know nothing about pulse systems except to say that I have not heard of anyone apart from Meyer who has got one to work, maybe I am wrong?
I am toying with the idea of using a current control device to keep the amps under control as the unit heats up. I gather from what I have read is that it is as advantage to have the unit running hot as more gas is produced in hot water.
I am not at this stage trying to run on hydrogen alone, I need to crawl before I attempt to walk.
I guess you could say I?m crying out for help. ?Help?!
EMdevices
Hi weggl,Ã,  welcome to the forum.Ã,  Ã, Right when you log in you might want to click the FORUM menu item and then select the right sub-forum that is applicable to your needs.Ã,  I'm sure there is a Meyers/Hydrogen link.Ã,  Ã,  We here discuss a so called Toroidal Power Unit.Ã,  Have a look around, it's interesting.
Hi sugra, thanks for the advice.Ã,  Right now my wire has about 0.4 or 0.5 ohms and from the 24 V battery I'm drawing about 40 amps, give or take a fewÃ,  (there's some voltage drop at the spark gap as well)Ã,
I also included a magnet after I did the measurements and the video, and the wire moved violently.
However,Ã,  I'm not so convinced the first movements I was getting are from the interaction with the earth's magnetic field.Ã,  Ã,  I think it's more plausable that the wires influence EACH OTHER,Ã,  and I say that based on how they vibrate, NOT UP AND DOWN but SIDEWAYS.Ã,  Ã, I'll have to calculate the 'B' field from one wire to the other, and then I can compare.
EM
EMdevices
Ok guys I cracked the mystery of the repeling ring.   :)
I hope none of you are disapointed if I just tell you.  I know I would be, I like to ponder and figure out something,  that's why I'm invovled with the TPU after all.
I'll put together a drawing to illustrate.
EM
c0mster
