A-King 21 - build discussion /investigation
Started by ramset, July 15, 2019, 09:13:34 PM
Quote from: Void on July 19, 2019, 06:18:11 PM
But does it really work? That is the question...
... or maybe the question is, to be or not to be COP >1?
It's OU if Rick says it is, and if you can't measure it, you obviously don't know what you are doing, you have cheap obsolete garage sale equipment,  and you need to watch more of those great teaching videos, and maybe even buy a kit or two so that you will understand. OU doesn't come from measurements, it has nothing to do with Joules in and out or COPs, it is the Heaviside Flow at Right Angles that is important. And you can prove this for yourself with a Violet Ray Tesla Coil (that isn't actually a Tesla coil) and a Big Capacitor you built out of some plates of metal and a sheet of plastic for a dielectric. It's simple, once you understand! See that fluorescent bulb light up? OU, Heaviside flow, QED. There is no other possible explanation for the results we are getting.
Hoppy
His looong monotone video presentations will likely lull you into a state of sleep but make an effort to stay awake folks, as some of the visuals are epic entertainment.  ;D
Big capacitor? That's not a big capacitor!
THIS is a Big Capacitor.
ramset
member Wesley donated some of those ,and other things for experimenters here to  use.  and loads of High voltage [super High voltage] stuff .must be crazy expensive !!
Tinsel I have to admit at the 2 min mark...when you place the magic foil enhancer  https://www.youtube.com/watch?v=f-aP7sk48jw ...
is that made of unubtanium ?
I believe Stefan has some fellow who is helping him with Ricks claim.
and hopefully a good presentation for the many members here who have learned what that Looks like over the years.and would gladly help replicate ...with 100% transparency .
Chet K EDIT To change to high voltage not high frequency
Thanks Grandma
Quote from: ramset on July 20, 2019, 09:10:41 AM
member Wesley donated some of those ,and other things for experimenters here to  use.  and loads of HF [super HF] stuff .must be crazy expensive !!
You know better than that.     :P     All my demonstrations are done with commonly available and usually very cheap materials. Except the ones that aren't....
In that video, the levitating Gray Matter is an ordinary pingpong ball painted with conductive nickel paint. The Volt Hoses are common bead chain, the little VanDeGraaff machine is made from stainless steel bowls from a restaurant supply store, its internal parts are made of pvc foamcore, paper clips and shimstock, a mabuchi can motor, and a belt made from wide rubber bands, and it is powered by a 12 volt motorcycle battery. Not counting the battery the most expensive parts are the switches. (One for power, and one for motor direction using the Secret of DPDT.) The antigravity chamber is a couple of plastic food containers. The chamber electrodes are pieces of aluminum duct tape carefully shaped and stuck down inside the chamber. And the "magic foil enhancer" is just another piece of that same aluminum duct tape with the backing still on, held in an alligator clip on the end of a bamboo chopstick. It is very important that the chopstick be bamboo.... and I am not kidding at all. The bamboo of the chopstick is like a million megohm resistor to slowly and gracefully drain away some of the high voltage static charge that builds up on the outside of the container and tends to neutralize the antigravity effect. Draining away _some_ of this exterior charge by using the Enhancer connected to the Chopstick connected to the experimenter's Hand allows the AG effect to build up to full strength again. If I used a fully conductive link -- well you can imagine what might happen.    ;)
Chet K
As someone who has actually exploded a 0.3 uF, 30 kV Maxwell oil-filled pulse capacitor -- Much Bigger than that grenade up above -- by rapidly discharging it in a severely overvolted state, and nearly died as a result .... all I can say is Be Careful.
EDIT: Be F......G careful. I got another chance. You might not.
