A-King 21 - build discussion /investigation
Started by ramset, July 15, 2019, 09:13:34 PM
a.king21
Quote from: Void on July 17, 2019, 08:53:39 PM
Hi a.king21. Unfortunately it's all just words unless someone can actually demonstrate it
in a reasonable way. :) At any rate what you said there is not what Don Smith talked about
that I have seen. From what I recall, Don Smith talked about 'disturbing the ambient' which supposedly causes
'separation of electron pairs' or something along that line which 'releases energy' and this energy is
somehow collected by the circuitry. I have already pointed out in the other thread that
Don Smith apparently did not create that 'Don Smith Effect' document, again from what I recall, so
there is no guarantee that DSE stuff really has anything much to do with things Don Smith actually said.
It has already been done a hundred years ago by Benitez.  i am suggesting some ways in which his device can be modernised.  As an example Edwin Gray modernised the Benitez battery idea and his splitting of the positive is exactly the situation where you have 2 batteries in series and charge 2 batteries in parallel whilst  powering a load between + 24 and +12 .  ie splitting the positive as he calls it.
a.king21
The vid and Benitez and the Ukrainian replication is basically this aspect of the Don Smith system: Don had several strokes by this time so some of his grammar was off. It was his parting gift to us before he died so I suggest we analyse it carefully. I jokingly call it the Moron level of comprehension, because those are  the words Don used.
partzman
Quote from: a.king21 on July 17, 2019, 08:49:04 PM
Partzman: Then I take it you disagree with Benitez. Especially his first patent.  May I ask where you see the flaw in his reasoning?
My one concern with Benitez is that in the loop back trafo that it is actually an induction coil  and not a trafo which would have an additional gain input into the system.
Again I ask specifically, what is the gain mechanism?  I don't see it in the Benitez patent.  Please explain in simple terms so I and others here can understand this phenomenon.  I'm not trying to be difficult but rather wish to understand but honestly, I just don't get it!
Regards,
Pm
Void
Quote from: a.king21 on July 17, 2019, 09:36:17 PM
https://www.youtube.com/watch?v=XkAMNFKjds4&feature=youtu.be
7 minutes in.
Hi a.king. I understand the concept of electrostatic induction, and I have experimented with it
using an earth ground to one capacitor plate, and only could ever get flea power out of such an arrangement
even when charging the other capacitor plate to at least 8 kV on a 0.1 uF HV cap at around 20 kHz. If there is a
way to make that work with reasonably high output power, I couldn't find it anyway. Maybe I am not quite enough
of a moron to get it. :)
