A-King 21 - build discussion /investigation
Started by ramset, July 15, 2019, 09:13:34 PM
Scopeshot of the little multivibrator with some manual button presses:
(LED On when signal is LOW)
NickZ
   Geofusion has not shown OU nor could obtain self running any device. Nor has made any claims about that either.   itsu has checked out. But the door is always open, at the Asylum. Where friends will always be friends...
a.king21
Ok Let me explain cos I am going to get some heat here.
I powered the slayer from batteries and looped.  So you are going to say batteries again.  well it was a first experiment so hang on and I'll do a schematic.
AlienGrey
Quote from: TinselKoala on July 18, 2019, 12:24:25 PM
No spark gaps in the Bearden schematics.
Please somebody give an accurate and complete schematic along with some description of how it is supposed to behave. And just how the OU manifests.
A Slayer that runs itself until dark. Precise schematic please.
I'm not sure on this one but I think from what i've been told its about halting any power fluctuations as it causes a magnetic flux and then dumping all stored capacitance dielectric energy into a pulse of energy usually a high voltage in the first stage if the protocol is not adhered to you get nothing it's about beating the rise time of the electron rumour has it
that's about 5 nano seconds 200 mhz but A.King says there is another way. the spark gap has to be low resistance .005 ohms, you would need at least 10 irf460 fets in parallel and then there is the fly back voltage to contend with but they can be cascaded.
And then there is this apparently he says it works. No he shows it working.
notice during the impulse all current must be activity halted.
AlienGrey
Quote from: TinselKoala on July 18, 2019, 12:27:46 PM
You can check out --- but you can never leave.
Don't you wish MarkE was still around? I sure do.
who is he ?  (you can't destroy energy (everything is energy EVERYTHING)
