Power from repelling magnets
Started by norman6538, July 20, 2019, 05:01:53 PM
norman6538
I'm sorry to say that my bellcrank is too sloppy and looses a lot of work out and I don't know how to make a better one.
So I picked up on Floor's twist drive and quickly cobbled two somethings  together today that is more promising than my power from repelling magnets.
You can see it here. https://overunity.com/16954/magnets-motion-and-measurement/msg543093/#msg543093
Hope you find it interesting. Floor has done a great job on his research and sharing it with all of us.
Norman
norman6538
I am on version 6 of Floor's twist drive and I made a variable lever with 3 different dowel diameters to be able to refine the power to set and reset the device and this is what I measured today.
1. The device is self setting. ie meaning take my had off and it goes from unset to set and twist and lift a small washer 12.5 cm.
2. to then unset and unlock from the twisted attraction it takes the same washer 2 cm of drop.
3. so that clearly gives 10 extra units of work for the switching necessary to make it self run.
The extra work is more than there.
Next I will begin my clock  work to make it switch from lifting to resetting mode making it a self runner with extra power out too.
Norman
norman6538
I use a given weight that drops 1 cm and via "Floor's Twist Drive" lifts 4 of the same weights 7 cm. which I call 28 units of work out. That would be 2,800% OU. It takes 6 units to make this repeat itself - 1 to set and lift and 5 to reset to repeat step 1.
But if there were some error in my numbers and even 500% were achieved then cascading this again and again would reach several thousand units over the input.
I will have someone I trust to verify the numbers soon.
Norman
norman6538
Today I have changed some things and derived 4,000% efficiency by dropping a weight 1 cm which moves a magnet closer to a twistable magnet which then lifts 20 of the same weights 2 cm giving a 1:40 ration.
Attached is a concept drawing without all the leverage details. I am now working on automatic switching to make it switch from that  excess work and run by itself.
I WANT TO THANK FLOOR AGAIN FOR SHARING ALL OF HIS WORK THAT MADE THIS  POSSIBLE.
Norman
