hammerFall gravity powered generator
Started by burnit0017, July 22, 2019, 09:59:18 AM
burnit0017
https://youtu.be/Dey3dxiOGck
https://youtu.be/SDkYRP7f2Dk
Hi, due to the limitations and expense of the large Neo magnets and electromagnets to push the pendulum used on the Gram project I am changing the input configuration, that is similar to a water powered triphammer configuration. I will use 5 balance beams with 25 pound weights. One beam will re-set as the rest are falling.
burnit0017
https://youtu.be/Dskcjq-N_5w
using 6 balance beams, it should create a condition of 125 pounds will always be falling
kajunbee
If I'm understanding your device correctly 100 lbs. will be falling only on first half cycle. On the second half of the cycle it will be lifting 100 lbs. As I see it once the first weight reaches the bottom it would have to be returned all the way to the top before the other 4 levers bottom out. Which means it would have to go up at a faster rate than it went down. But maybe I'm missing something.
burnit0017
Hi, only one 25 weight resets at a time, maybe the example videos will help.
https://youtu.be/lFIu0QBd6DE
All the parts are fabricated I should have more to report in a few days. Cheers
kajunbee
Ok, one other point that your probably already aware of. It will take some amount of weight just to balance those levers. This will subtract from your expected 25 lbs. i believe.  You may have to go with 30 lbs. or more to offset this loss. Unless you think you can live with it.
