Thanks to ALL for your help!!
Does using a narrow hollow-metal-cylinder as a conductor, multiply the power ?
Started by postingsite, July 29, 2019, 08:35:17 PM
postingsite
What if you used an aluminium-core in a coil, and only powered / pulsed the coil ( also try dc ) and attached wires to both ends of the aluminium-core to see the output of the aluminium
postingsite
For copper-cores,  I found the following two pages very interesting,  although they no longer load on my machine,  many interesting things on these two pages including  "Westinghouse polyphase, interlocked toroid transformer"   .
https://www.overunityresearch.com/index.php?topic=264.0
https://www.overunityresearch.com/index.php?topic=264.25
Quote from: postingsite on August 04, 2019, 02:07:11 PM
Maybe an effect could only be attained if the aluminium-core is like a long thin strand rather than the bulky more usual cores,  or maybe not.
Maybe AC is used in long distance power lines to get some type of overunity / reactive effect out of aluminium .
I find some results on the internet for  "aluminium reactor",  although different sites refer to different types of devices .
kajunbee
I don't know if I could answer your question with any real authority. There are too many gaps in my knowledge of electrical theory. I'll give and example of what has me scratching my head. Take pen and paper and draw a loop of wire with a positive and negative on each end. Along this wire draw your hollow copper tube. Then start drawing small circles all along your wire. Keep drawing ever larger circles around each one. These will represent the lines of flux of the magnetic field. What you will see is that the poles of your magnetic field is in the center of the loop. Not on either end or sides of your copper tube. This is part that has me stumped. Will there be a voltage induced or will it cancel out. This is probably very basic stuff for Engineers and more knowledgeable members. Maybe this post will catch someone's attention and they can answer for both of us.
kajunbee
I have to add that the applied voltage is ac. It was my mistake to say positive and negative.
kajunbee
Ok, I asked a some questions and it was suggested to me that a coax could be considered a conductor inside a hollow tube. I threw together a quick little test.
