Mgnetic shield?
Started by telecom, July 30, 2019, 02:47:16 PM
telecom
The only reliable way to overcome the shield problem is connect two cifta units
back to back, the way they are now.
Then rigidly connect shields.
telecom
When you stack several small magnets together, the polarity of them getting rearranged,
and out of several small magnets appears one big magnet, divided in the middle with
north/south polarity.
Floor
Quote from: telecom on August 01, 2019, 08:38:00 PM
Which citfta unit?
Last I looked,  he had presented 3 variatiions.
Floor
Quote from: telecom on July 30, 2019, 02:47:16 PM
I put together two repelling magnets, opposing each other.
I inserted a similar magnet between them.
It was attracted to one magnet, and  simultaneously repelled by another.
I tried pulling it out - the force of pulling out is considerable, so high, that I couldn't pull with my fingers.
Attaching the image - couldn't place camera at the different angle, since one hand was holding the setup.
This is not one of the designs which I had presented. Apparently, it is a misinterpretation one of the designs I presented.  Where that misinterpretation got started ?  Lumen ? Tinman ? and apparently by you as well ?  I don't much care at this point.
Although I have since, addressed it on several accounts, and I'll say it again, for those whats hearing impaired.  Not a design I had presented.
But here is the solution to it's "problems" if you are so inclined as to grok it.
               floor
Floor
Next......
Will the shielding magnets, prevent the repelling of the
output magnets when it is between them ?
Will the shielding magnets be easilly removed from or
installed into between the output magnets ?
       tun in next week
