Up to 99% less mass and energy consume by aequivalent comfort
Started by lancaIV, August 29, 2019, 07:14:39 AM
Reply #38 : 2021 Standart : 100 W e-generator sufficient
                                           1000 W e-generator https://geospatial.blogs.com/.a/6a00d83476d35153ef022ad3c0d118200b-popup
        NO RECHARGE,up to 11 years consumer loading
Cost to mass produce           $40 per KWh or 1000 Wh
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=19951107&CC=US&NR=5463914A&KC=A
In comparison, when a DC 12 V mini motor with full load capacity 25 g, 560 mA, running at 13340 rev./min is used,
a plurality of such motors can be assembled and operated in association with a suitable number of down-speed gear sets so as to obtain proper operation speed.
The power consumptions thereof in the same conditions as above, are compared with the conventional motors to conclude
that at most only one eleventh of the power consumed in above cited motors is required.
With such an arrangement, the present invention can be applied to a wide range of fields, providing different kinds of driving capability according to practical requirements.
The spur gear 311 at the other end of the main output shaft 31 of the output gear set 3 of the whole assembly is then engaged with a motor driven device
such as a pump, a compressor, a power transmission or device of the like, by way of a belt 7, a chain 8 or a gear 9, as shown in FIGS. 8, 9, 10.
[0001]
The present invention relates to the electric motor drive of devices, machines, traction drive devices and the like.
Which are driven at a not very high speed and medium to high torques.
It goes f.e. household appliances such as washing machines and dishwashers, refrigerators, air conditioners, fans, but also electric cars or motorcycles.
                                         University/basic school  students study world-wide :
heat-pump conventional average C.O.P. 3 , 2021 technical/commercial standart,
new/used model for experiment/prototyping :
with above power saving transmission ?
+            https://uspto.report/patent/app/20180340713          https://www.patentauction.com/patent.php?nb=13727
The device in testing produced 45% of the overall consumed energy and put it back on the grid in prototype testing.
This device can be retrofitted into 95% of units manufactured in the last 10 years and can be a welcome addition to new units currently manufactured.
Dowdy-prototype with power saving transmission :
                                              electricity to thermic stream to electricity cycle
millions of heat pumps/chiller for  private household,green house,vegetable/fruits conversation ( cold function !),medical freezer(vaccine)
for hot/warm heat pump effect : heat pump + power saving transmission for C.O.P. 30 and for closed cycle :  .... ( ;) )  or later : Nano-Boxx
and later from later : the Ferreira capacitive windings e-tractor with exemplary 68 mA and up to 350 V for up to 5 KW kinetic force output
                                              heat pump warm/cold effect by C.O.P > 100
                                              but e2t2e cycle enclosed > C.O.P. 100 (!)
in warm climate regions world-wide by intelligent household appliances arrangement and https://mtbest.net/wp-content/uploads/sites/12/2021/03/household_efficiency.pdf by power saving transmission use and electricity saver heatelements+controler
these 0,8 KWh( 0,1 KWh freezer and 0,7 KWh the other devices) per day can be reduced
                                                         to < 0,5 KWh per day,
                                                        up to 250 Wh per day
let us take a conventional fridge ,100 Watt rated electric compressor motor DC or AC ,in average 8 hours per day work :
instead Mr. Chalko his 100 Wh per day freezer modification we apply to the DC ( stable VOLTAGE)  e-drive :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=69&ND=3&adjacent=true&locale=en_EP&FT=D&date=20070201&CC=JP&NR=2007028879A&KC=A
10X nichrome wires = 100 W DC to (100 V x 1A)/10 wires =          10 W DC input
                            8 hours per day work                          a           10 W DC input = 80 Watt per day refrigerator consume (average)
                                  as same effect like proclaimed power saving transmission !
for nichrome wire application experiments : https://www.youtube.com/watch?v=YrHN6iTMtvM
or : f.e. type  such https://allectra.store/en/sports-leisure/beach-and-pool/electric-portable-fridge-24-l/
800 Wh conventional consume in work x 0,45 ( for Dowdys 45% recuperation)                 = 360 Wh recuperation
David Yurth generator coil coating 1,333 output enhancement/increase  360 Wh x 1,333 = 480 Wh recuperation
not only device e2t2e cycle but total household e2t2e recuperation cycle
+ solar thermic energy ( Mr.Chalko )or wood (Vale,Autonomous house) or bio-composter-heatelectric conversion
who likes " mad financial science " experiments :
Kenmore 30 W fridge (24/365 working) + steady/permanent Dowdy-working generator output for charging
a. the rated 2,5 W electric motor
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=19940318&CC=FR&NR=2695768A3&KC=A3
b. the rated 30 W to 20 W or less ( by 10% efficiency solar panel 180/30 W ratio = 120/20 W ratio) lamp consume
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=28&ND=3&adjacent=true&locale=en_EP&FT=D&date=20120322&CC=DE&NR=102010035706A1&KC=A1
                more than 100 Watt DC (solar cell) or pulsed DC ( capacitive array)per hour generation
for (solar) heat generation : https://judbarovski.livejournal.com/133020.html
                                               or http://www.redrok.com/main.htm#gsc.tab=0
A litttle 2021 standart overview : Richard Fradella up to 99% conversion efficiency motor/generator (with coating ?)
        https://patentauction.com/patent.php?nb=14106       10 KW/Kg
DC or AC input and/or output ? with Uchiyama nichrome resistor (DC/AC inverter ? interface) application ?!
Re: Reactive Current - Parallel RCL
« Reply #70 on: Today at 12:06:02 AM »
[size=0.85em]
Modify
Fine,to refind Kirchhoffs rules by in-law and out-law conditioning : PARA-/DOXON
https://paxscientific.com/        hydraulic/electric
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=1941593A&KC=A&FT=D&ND=3&date=19340102&DB=EPODOC&locale=en_EP
line 25-36,first document page
https://www.youtube.com/watch?v=suIAo0EYwOE
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Teslaventil
https://en.wikipedia.org/wiki/Tesla_valve
and search machine and/or youtube : Tesla valve
( https://www.newscientist.com/article/2277794-century-old-water-valve-invented-by-nikola-tesla-could-have-modern-use/
   https://www.nature.com/articles/s41467-021-23009-y      )
https://en.wikipedia.org/wiki/Coand%C4%83_effect
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=3&ND=3&adjacent=true&locale=en_EP&FT=D&date=19210316&CC=FR&NR=514684A&KC=A
to
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=19210709&CC=FR&NR=521330A&KC=A
and
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=13&ND=3&adjacent=true&locale=en_EP&FT=D&date=19220721&CC=FR&NR=540979A&KC=A
and linear
https://worldwide.espacenet.com/publicationDetails/description?CC=FR&NR=667647A&KC=A&FT=D&ND=3&date=19291018&DB=EPODOC&locale=en_EP
Pour concevoir et réaliser la présente in vention, ii fallait d'abord trouver une interprétation neuve du phénomène mai connu de l'induction électrique.
L'énoncé de cette interprétation est né cessaire pour définir exactement les caractéristiques essentielles de l'invention, de manière intelligible, soit : .
1 Le flux inducteur, issu d'un foyer quelconque (pile, accumulateur, etc.) re-foule le milieu ambiant, comme le ferait la force centrifuge d'un volant en rotation.
2 Le flux induit .(ou, pour mieux dire, le reflux) issu du milieu extérieur, révèle l'énergie immense mise en jeu, durant les oscillations de la masse fluididique spa tiale revenant vers son équilibre normal. Ii s'assimile à la force centripète de l'air, sollicitée par la rotation d'un volant.
3 L'énergie induite (qualifiée centri pète), est toujours plus puissante que celle (qualifiée centrifuge) ou inductrice qui est la cause perturbatrice de l'équilibre spatial.
4 La puissance du courant induit (capté dans l'espace) est en proportion di recte de la sensibilité de l'instrument récepteur et de sa capacité électrique.
5 La bobine d'induction actuelle, for mée de deux circuits indépendants et rap prochés (primaire et secondaire) comprend un récepteur commode et très sensible qui est le circuit secondaire ou induit .
6 La capacité électrique dudit récepteur dépend de deux facteurs : tension et intensité;
l'élévation de la tension étant di rectement proportionnelle au nombre de spires induites, multiple de celui des spires inductrices (ce qui est connu),
et essentiellement, l'élévation simultanée de l'intensité étant directement proportionnelle à la surface de section du conducteur induit,
indépendamment de la puissance du flux inducteur et du calibre du conducteur primaire (ce qui était insoupçonné).
Toutes les machines d'induction ac- tuelles (dynamos, alternateurs, transformateurs, bobines de Ruhmkorff, etc.) sont considérées comme de simples transfor- mateurs de l'énergie (travail en chaleur, électricité, basse tension- en haute tension, etc., et inversement).
En réalité, la présente découverte démontre
que le flux inducteur et le flux induit sont deux formes opposées de l'énergie (l'un centrifuge, l'autre centripète)
et que la bobine d'induction bien comprise n'est pas un simple transformateur, mais un merveilleux multiplicateur d'énergie.
La puissance remarquable de l'étincelle de rupture confirme pleinement cette théorie
et prouve que le flux induit (centripède) est toujours plus énergique que le flux inducteur (centrifuge).
improved fluid (recycling) technology
https://books.google.pt/books?id=hcTMCgAAQBAJ&pg=PT155&lpg=PT155&dq=edginton+vacuum+cleaner&source=bl&ots=OtQwW899Ip&sig=ACfU3U0VRSKqY-QsKeQ9OFL0wgN-MkzHkg&hl=de&sa=X&ved=2ahUKEwi7qLObko7xAhXJz4UKHT1KCyUQ6AEwEnoECBMQAw#v=onepage&q=edginton%20vacuum%20cleaner&f=false
http://www.g0cwt.co.uk/arc/ 250 W instead 1400 W ( first consumption improveable)
https://showerloop.org/  90% reduction in water usage and 70-90% in energy reduction for a 10 minute shower with a flow rate of 10 l/min
    https://www.youtube.com/watch?v=aePwfWOT-Gw
related phase https://en.wikipedia.org/wiki/Inrush_current and voltage                        /     average current and voltage
lecture about inrush "administration"
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=ken&IN=kazumi+masaki&CPC=&IC=&Submit=Search
                                             DC or AC or pulse/pure phase/ inrush VA converter
I tried in the 2000 beginnings to introduce the Cosby-engine,here in Portugal : no feed-back from industrial side .
https://worldwide.espacenet.com/publicationDetails/mosaics?CC=CA&NR=973375A&KC=A&FT=D&ND=3&date=19750826&DB=EPODOC&locale=en_EP
to
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=11&ND=3&adjacent=true&locale=en_EP&FT=D&date=19970506&CC=US&NR=5626459A&KC=A
      principle compared Casimir plan Vortex plates converter !
and principle compared https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Schukey-Motor
   http://www.rexresearch.com/platen/platen.htm
( underestimated his oeuvre and possible industrial/commercial effect
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=baltzar+von+platen&CPC=&IC=&Submit=Search )
Edginton turbo-cleaner : in tube micro-turbine for partial fluid to electricity and average input demand diminuation
E                   -cleaner : with capacitive winding motor   14 W instead varistor controled 250 W or conventional 1400 W
Edginton technology use ( see his web-page)
Einzelraumbeluefter mit Gegenstrom-Waermetauscher
Single room ventilator with counterflow heat exchanger  1 Watt per hour consume
Central house-conditiong with counterflow heat exchanger
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=5&ND=3&adjacent=true&locale=en_EP&FT=D&date=19780418&CC=US&NR=4084408A&KC=A
                           https://www.level-recuperator.nl/over-ons
                                                Smartbox
               The system COP is > 10, depending on the conditions.
Studying and learning from the really BESTS ! And improving for NEXT LEVEL !
By stimulus : https://www.brainlight.de/presse/publikationen/die-4-gehirnwellen-typen.html
and professional preview https://faithpopcorn.com/the-popcorn-report/
conditionized : 1982 and L.A. November,2019     https://www.youtube.com/watch?v=eogpIG53Cis :
        Magnetic field administrated Flycars
[size=0.85em]
« Last Edit: Today at 04:34:40 AM by lancaIV »
                                               Geral Law Theory                     Specific Law Theory
Psychologie : Luescher,Vixier-Bild, Sigmund Freud Ich     -Ueber-Ich - ES             to Heinz Ryborz Ueber-ES
Iceberg ,Paretto Pyramids( 20/80),Gregory King-Davenant actio/reactio law,Walras-v.Weizsaecker,Bionik:Ingo Rechenberg Analogon
Gramberg,Ferdinand Cap,Winter( water and motor),Goldene Schnitt,Hagedorn,Constantinescu
                                      statics versus dynamics : quantitative and qualitative value scale
                        Geral : square law and inverse  square law  squareroot , root V plenitude/magnitude
                       Specific : cube law and inverse cube law      cuberoot     , root V plenitude/magnitude
                                     LIVING PHYSICS
                                    1           =           1
death maths,statics       1/2         =          1/2
dynamic physics,GLT     1/2         =          1/4
dynamic physics,SLT      1/2         =          1/8
https://www.google.com/search?q=youtube+tesla+numbers&rlz=1C1AVFC_enPT930PT930&oq=youtube+tesla+numbers&aqs=chrome..69i57.8273j0j7&sourceid=chrome&ie=UTF-8
                                     LIVING NUMBERS
Wie bewerten international OECD/BIZ Boersenanalysten und Staatsfinanzbeamte deren Zahlen ? Statisch oder dynamisch ?
https://de.wikipedia.org/wiki/Fundamentalanalyse
Lohn-Preis-Spirale up/down square root          Lohn-Preis-Kredit Spirale up/down cube root
                                           8-er-Bahn : https://www.youtube.com/watch?v=KgmWAv6q5EM
                                        was hoch HINAUS will kommt bestimmt (sehr viel tiefer) wieder runter
https://www.whitewall.com/de/mag/goldener-schnitt       https://www.youtube.com/watch?v=h3m93VUBw3Q
https://translate.google.com/translate?sl=auto&tl=en&u=https://www.sexmedpedia.com/farben-gefuehle-seele/
The choices are enormous. In the eight places on which the test person places the colors alone, he( and she ? ::)  and it ?) has 40,320 options for eight colors!
                   schwarz-weiss oder blutig : tief-rot / tief-blau oder irgendwie dazwischen ,their FUTURE PREVIEW
        wow,which DYNAMICS !
https://translate.google.com/translate?sl=auto&tl=en&u=https://www.arm-und-reich.de/verteilung/wahrnehmung/
( so nebenbei : Grosseltern/Eltern/Kinder(Enkel) Haushalte = 3(4,5,...?) Haushalte = 1x identische 3Generationsfamilie ,betreffend Erbe)
                                                       Gleich und Gleich gesellt sich gern (irrtuemlich),besonders statistisch
        bi-lateral                           irreal : 1  /  1  = 1           ( 1/2 )( 1/2)=1             real : 0,5 x 0,5 = 0,25
       tri-lateral                           irreal : 1/1/1  =  1           (1/2)(1/2)(1/2) =1        real : 0,5 x 0,5 x 0,5 = 0,125
        psychologic/physical market/specific object "capital"-value appraisal/gross valuation less credits(in-/direct)
       https://translate.google.com/translate?sl=auto&tl=en&u=https://www.makler-vergleich.de/immobilien-bewerten/gebaeudewertermittlung.html
https://translate.google.com/translate?sl=auto&tl=en&u=https://www.ramom.de/rechtsthemen/39-mietrecht/135-wirtschaftlichkeitsgrundsatz.html
Da bei jedem Kredit-Vertrag(fuer gesamten EURO-Handelsraum gueltig)  der Kredit-Geber juristisch zum Kredit-Eigentuemer des Kreditobjektes wird,der Objekt-Halter nur "Besitzer"-Rechte/Pflichten innehat, ist das Finanzunternehmen wie im obigem Artikel als "Vermieter" juristisch zu bewerten und behandeln!
Nach inzwischen gefestigter BGH-Rechtssprechung hat der Vermieter den Grundsatz der Wirtschaftlichkeit zu beachten. Diese vertragliche Nebenpflicht des Vermieters bedeutet, dass der Vermieter bei jeder kostenauslösenden Maßnahme das Kostennutzenverhältnis beachten muss.
Will ein Besitzer/Kredit-Objekt-Halter renovieren/sanieren :
Kosten-Nutzen-Verhaeltnis Evaluation/Gutachten seitens Finanzgebers/Objekteigentuemers ! PFLICHT ! PER GESETZ !
Schadenersatzpflicht ! Bei Gesetzesnichteinhaltung !
Gegenueber Besitzer und sowohl Mietern !
Und : Schmerzensgeld = zwecks Wiedergutmachung und Aufrechterhaltung der Finanzunternehmungs-Existenz !
Gegenueber administrativen Staat (3 .Gewalten-geteilt: Verfassungsschutz und Behoerden )und Justiz :
Normen-Kontroll-Verfahren ! EURO-Mitglieds-Staaten-weit !
Misztrauen-Votum gegenueber alle Parlamente !
Das Geld-Wesen IST a. Parlament-s-unabhaengig b. Justiz-unabhaengig c. soziologischen Staatsrepraesentant-unabhaengig
                                   nach Verfassungsstatut : offizielle 4.GEWALT
( Medien : 5.te oder 6.te ,wenn als 5.offizielle Gewalt die freien Sozialversicherungstraeger zugerechnet werden,mit eigenem Parlament
   aber auch hierbei : Kosten-Nutzen-Evaluation PFLICHT und Niedrigstwert-Praemisse : https://aok-bv.de/lexikon/w/index_00056.html
   fuer Ueberleistungen gesamte Vorstand Vermoegens-haftend ! )
  Andere Zeiten,andere Sitten : Nachlaessigkeit zu "ZERO TOLERANZ" und RE-EVOLUTION zu vollstaendiger GESETZESMAESSIGKEIT
wie als Beispiel
https://www.haufe.de/compliance/recht-politik/ex-vw-chef-winterkorn-in-usa-und-auch-in-deutschland-unter-druck_230132_450458.html (VERHAELTNIS-MASZ : 10 MIO/33 MRD ?)
Nicht VW ,Vorstand/Aufsichtsrat,kann sich einigen,sondern die dieses Unternehmen beherrschenden Eigentuemer : die KREDITGEBER !
  heisst ,nach EURO-Banken-Union : EZB bestimmt den juristischen Junktim !
Pieech&Porsche nur anteilige Eigen-Kapital-Halter ! Juristisch : nicht Eigentuemer !
Tesla Inc. : reale Eigentuemer ? Elon Musk:  Eigenkapital-Anteils-Halter (Aktien unbelastet/gepfaendet ?)
       media-"market"-value 1 000 000 ,by fundamental analysis object value 80 000 gross,less 800 000 credit direct = Oh-la-la !
                                          broken legs,up to Genickbruch/Face-Bruch ::) : Kotau !
                                          especially: the own kanailles =  from "rich" kids to poor kids ,no money for Uni study,car,holiday,......
        Anymore :   Halli-Galli
               https://www.youtube.com/channel/UCHnyfMqiRRG1u-2MsSQLbXA  veritas et rigor
desert to OASIS
https://www.youtube.com/watch?v=_pT1gKFi82E
http://www.canlaser.com/en/Deserts.html
https://www.youtube.com/watch?v=4Q_z-vwCAhk
https://www.youtube.com/watch?v=9dsWaT6Pl2Q
https://www.youtube.com/watch?v=KdFIHecZDfc
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=8&ND=3&adjacent=true&locale=en_EP&FT=D&date=20031204&CC=US&NR=2003221995A1&KC=A1
[0004] We can decrease the energy consumed in distillation by 95% and decrease the time needed for that distillation.
[0006] USE: for all distillations (alcohol, crude oil, convertion of salt water into fresh water and all types of distillations)
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=2002170292A1&KC=A1&FT=D&ND=3&date=20021121&DB=EPODOC&locale=en_EP
their "greenhouse"  https://n55.dk/                    to        mega -"inflatable bubble" for in-side farming
https://www.google.com/search?q=inflatable+greenhouse&rlz=1C1AVFC_enPT930PT930&oq=inflatable+greenhouse&aqs=chrome..69i57j0i19l2j0i19i457j0i19i22i30l5.10809j0j7&sourceid=chrome&ie=UTF-8
https://www.google.com/search?q=inflateable+bubble&rlz=1C1AVFC_enPT930PT930&oq=inflateable+bubble&aqs=chrome..69i57j0i13l5j0i22i30l4.8817j0j7&sourceid=chrome&ie=UTF-8
outer bubble surface coated with translucent solar liquid converter
https://www.google.com/search?q=inflateable+bubble&rlz=1C1AVFC_enPT930PT930&oq=inflateable+bubble&aqs=chrome..69i57j0i13l5j0i22i30l4.8817j0j7&sourceid=chrome&ie=UTF-8  for air compressor sourcing
 Wow !
The Vortex application in solar ponds,bioreactors(algae growth),natural water ponds(aerating) !
https://www.youtube.com/watch?v=YMDJA4UvXLA
https://www.youtube.com/watch?v=0aVhlOnR-EU
salt water ponds https://www.youtube.com/watch?v=Ob9XouO-SZU
aqua-culture/hydro-ponics https://www.youtube.com/watch?v=VBspR2p0YYM
                                       https://www.youtube.com/watch?v=yhcAOE2JOVs
                                       https://www.youtube.com/watch?v=w0PqwN5FzUA
Permaculture                    https://www.youtube.com/watch?v=YBPLrr9Hph0
https://www.jovoto.com/projects/300house/ideas/12769
The Vortex rotor effect : offered by PAX SCIENTIFIC  their experiments/test field results
https://patents.justia.com/assignee/pax-scientific-inc  https://patents.justia.com/patent/7862302
from their description :
The circulation removes the stratification and results in the aerated surface layer being continuously mixed with all other water, thereby providing aeration to the total water body. These advantages displayed by the embodiment are realized with a motor of very small, relative size. In testing, rejuvenation of a pond having a surface area of approximately one acre (1.7 million gallons) was achieved within two weeks by operation of a motor of 40 watts.
In an alternative test, a one-half acre, 16-foot deep, million-gallon water supply reservoir was fully mixed in 20 hours with a 24-watt motor.
https://webecoist.momtastic.com/2013/01/28/14-off-grid-projects-to-cut-your-energy-and-water-usage/
https://www.youtube.com/watch?v=tAN0QNQFDbg
https://www.youtube.com/watch?v=qffBbFbBj2Q
https://www.youtube.com/watch?v=GzDrnoGdLO4
https://www.youtube.com/watch?v=t8I49nzWlMU
water + motivation : desert to restorated living land  https://www.youtube.com/watch?v=KTpaJn22w4I
