Up to 99% less mass and energy consume by aequivalent comfort
Started by lancaIV, August 29, 2019, 07:14:39 AM
From electron-/ion-flow processor to photon-flow processor :
https://www.n-tv.de/wissen/Mit-Lichtgeschwindigkeit-in-die-KI-Zukunft-article24504598.html
https://www.nature.com/articles/s41566-023-01233-w
Vertical Cavity Surface Emitting Laser (VCSEL).
reminds
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=9&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931012&CC=US&NR=5252176A&KC=A#
100 times faster means actually 1,5 hours answer finding time in less than 1 minute,
1,5 minutes in 1 second !
Great advance for physical technical process artificial simulating programm !
100 times less energy consume by previewed 1000 Wh/Kg energy storage devices :
smaller and lighter communication devices !
Smart credit-card size or multifunctional and cheap 'watch'-communicator :
https://pt.aliexpress.com/w/wholesale-watch-phone.html
wmbr
OCWL
p.s.: https://www.n-tv.de/wirtschaft/KI-wird-laut-Elon-Musk-alle-Jobs-ueberfluessig-machen-article24508217.html
K.I. or A.I. as ' artifial brain '-administrated society , final social target
Quote from: ramset on October 23, 2023, 01:53:33 PM
Lanca
Hope _Tings_ are good ..
Your Article
https://www.fairland.com.cn/allnews/fairland-redefines-pool-heat-pump-energy-efficiency-with-cop20.html
With 20kW heating power for every 1kW input power,
End quote ( yes home heating etc please...
Seeing that in published claim ?
Clickbait or "WOW"!?
Loop it or go home ( daisy chain units to steam ??
More please ...( schematics/build details/ help[/
Respectfully
Chet
By 20x/or 40x  C.O.P. reaching a closed cycle !?
Question : the high C.O.P. devices   heat exchanger surface temperature ?
https://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=U1&LOCALE=en_EP&NUMBER=20304290&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
[0006]
Convert 70°C into electrical energy with an efficiency of approx. 50%. An effective new type of compressed air motor is required for the process mentioned.
Alternatively :
C.O.P. 10x
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20200514&CC=DE&NR=102018008797A1&KC=A1#
and the/an efficient (hot)air motor
This is - by more conversion steps- the donut/round tube MHD/EMD process principle showing !
Interestant,now the first AI/Cloud Intelligence assisted gadgets :
https://www.allround-pc.com/news/2023/humane-zeigt-erstmals-wearable-mit-ki-und-laser-projektor
and Neuralink chip transplant .
Included : 24/365 user observation !
Data directly to ,formerly : https://en.m.wikipedia.org/wiki/SCL_Group  , comercial interests groups ?
Cloud Intelligence Agencies ,abbreviation : C.IN.A. ?  ::)   'C.I.A.' is occupied,right priority !  ;D
https://de.m.wikipedia.org/wiki/Francis_Galton " Aristocratical Eugenics "
https://en.m.wikipedia.org/wiki/Three_Laws_of_Robotics
Fine,
24/365 Evolutive ' Cloud Eugenic Program '
            From ' underunity' to ' overunity',step-by-step
A cube, with volume , defining a ' room '
Lenght 5 meters
Wide 4 meters
Hight 2,5 meters
This gives 20 sqm floor area
This gives 50 cbm volume/space
This gives (2x5x2,5)+(2x4x2,5)+ ( 2x 4x5) = 85 sqm cube surface
The cube material ,from hot/cold ambient i-/n-sulation, PUR(Polyurethan) or EPS(Styropor)
We take EPS with 0,0034 W/m and cube foam a. 3,4 cm thickness b.6,8 cm thickness
giving ,classical K(oefficient)-value a. 1,0  and b.0,5
The 1,0- Koefficient applied :
outside temperature 0°C and wished cube volume inside space  average temperature 20°C
shows :
85 x 1,0 x 20 ( the spread) = 1700 Watt heat is to generate to get this 20°C average condition in this cube
The half in the 6,8 cm thickness cube = 850 Watt heat generation
This cube represents an ' home-mobil/e',trailer . Here window-/door free .
The Koefficient 1,0 cube air conditioner electricity need to generate/pump/displace heat :
1700 W : C.O.P.  ? = ! VA
? : 10x = 170 VA
? : 20x = 85  VA
? : 50x = 34 VA
This VA need to half by Koefficient 0,5 (= 6,8 cm foam thickness )
This VA need to quarter by Koefficient 0,5 and claim : OSMA TECH insulation coating apply
OSMA TECH coating / Dewar flask inside IR mirror reflecting effect / astrofoil (airbubble +  alu-film)
So we take as technical optimum,not possible maximum, the Koefficient 1,0 ( 3,4 cm foam thickness) and the OSMA TECH inside surface coating to get by temperature spread about 20° Kelvin the numerical given space volume the VA electric pump drive for heat displacement work need :
850 Watt heat delivered by C.O.P. 20x machine lever work = 42,5 VA
The 3,4 cm foam ' house' we have as reference : Germany, " Igloo-Village" ,house in a box
The Architecture-Prof.Peter Huebner his collapsible 'Casanova'-space-modul in EPS/Styropor style
As EPS thick wall construction concept known :
https://isorast.de/
Koefficient 0,25 - 0,15
Similar in Japan,but not as transportable/relocateable unit :
https://www.google.com/search?q=iglu-village+foam+dome&ie=utf-8&oe=utf-8&client=firefox-b-m
This ' relocateable foam house ' the semi-autonomous life equipment :to find as typical trailer/caravan inventary
Water delivery by ambiental dehumidification,drop to liquid,filtered ~ AWG
Water recycling by transportable water plant
Often people oversee and do not remark many own ' matter to energy'- sources :
the daily household garbage,each Kilogramm +- 4 KWh energetic value : plasma-incinerator ( and heatelectric conversion )
Bio-composter- gas/heat
Black water ,sewage to energy
Free energy and ' overunity machine' concepts are to find in thousands kinds of conceptual manner,2023 now ' open source = owner-free'
What/which is the economical worth from a ' living space' by new construction costs,after 10,20,30 years book-value amortization ?
Per sqm new construction ,with included bath and basic kitchen equipment :
book-value : 250 Euros,without tax
After 10 years,by progressive amortization quotes : 4 years x 7% ,6 years x 5% = 58% value-losts
After 10 years this object book-value : 105 Euros
After 20 years : the first 10 years 58% losts,followed by 6 years x 2% and 4 years x 1,25% = total 75% losts
= 62,5 Euros used object book-value
To 30 years : 75% losts + 10 years x 1,25 % = 87,5% ordinary book-value amortization losts
= 31,25 Euros object
From 2023 30 years review :
villages,cities,metropoles
= 31,25 Euros is the banking sector the base-mark to estimate the maximal possible credit offer to buy or modernize an object
The plot/ground classical not allowed to creditize,to fix a price,a worth !
But as we know that theory and theology stays passive,the minimum assurance/warranty to get a right ground/plot book-value to amortize the given value progressive !
After 40 years,30 years = - 87,5% + last ten years 10 x 1,25 % = totally 100% object  book-value extinction .
Book-value ZERO cities and countries ,amortized,economical extincted ! Economics : totes Kapital
Free Energy devices are produced,the converter/machine/generator has its material worth/costs/price !The physical process is free !
The converter/machine/generator/ has its price,the use over the time amortized as :
€/KWh or $/KWh or ¥/KWh = investment-input per KWh output economical efficiency !
1¢/KWh electric is by object overtime financial amortization possible and reached !
Future and work power creates for the U.S.A. citizen a benchmark :
Taking Ex-President George W.Bush his 1 US-American ~ 2 000 000 $ economical value
        1 Afghani         ~       20 000 $ economical value
Tesla Inc. Optimus ,human-similar machine ,does not give the US-Americans more worth,by costs it decrease the economical US-American worth also to 20 000 $ net !
Each world habitant : maximal 20 000 $ economical value !
Actually 90% from all professions are substituteable by ' Robotik' .
The last 10% substituteable by DIY .
But it is not a surprise reading in 1930 'popular mechanics'-magazine an article about worker-number substitution by 1 machine :
60 worker(-bodies) ( less 1 machine driver = directly now 59 disemployers or as worker being ready to earn up to 90% less )
Reading in the 90' about house construction worker substitution by 1 machine :
10 worker ~ 1 construction machine
Robotic is an ' overunity system' :
maschine consumption in Joule compared human worker consumption in Joule for the same work effect,calculated as 8766 hours per year comparison !
Physics/Physiology/Psychology :
The above demonstrated cube with Koefficient 0,5 and 20°Kelvin inside/outside temperature spread :
by pure arithmetical calculation the energetic heat need : 850 W
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=21&ND=3&adjacent=true&locale=en_EP&FT=D&date=20080925&CC=DE&NR=202008007815U1&KC=U1#
A Resonator,an electrical reversible heatpump system ,needs as electrical input for the given/wished condition  :
the application description translated claim/statement
:For example, a room with a floor area of 20 m2 can have approx. 80 Watt can be permanently heated to a body-compatible temperature of 18-20°C at a voltage of 35 volts.
So a periodic swinging permanent ( cold climate period) working electric source in search !
Functional with C.O.P. 10 .
Means 8,5 units surplus energetic process gain,1 unit e-storage recharging and 0,5 units process losts.= static/rotative generator closed -feedback/selfcharging- cycle
Or full C.O.P. 10x apply and the electric input has to be 8 VA(Watt)
by 24 hours 0°C outside = 24h permanent heating  x 8 VA = 192 VAh
and this delivers ,100%,the kitchen  kineto-electro thermodynamic cycle machine,vulgo fridge/refrigerator,efficiency improved by hot fluid medium stream force converting generator installation,and cause 2/3 stand-by function :
surplus energy capacitive or cellular storage .
(Clearly,the fridge door can be partial or fully opened to get permanent fridge working,and parallel process reversible the generator hot fluid stream force to electricity generating )
Each fridge transforming to 'overunity-process-machine ' .
Each reversible used heatpump,space cooling,to ' overunity-process machine' .
Each Atmospheric Water Generator,using the thermodynamic cycle cooling process,humidity condensation function,transforming to ' overunity-process machine'.
24/365 ' net zero electric balance ' water and/or cooling generation .
Indirectly also ' heat' = compression  : hot machine/cold machine crossed ,24/365 heat generation .
This is ' open source= owner-free"- technique and owner-free technology :
ready for the cheapest possible industrial production costs condition
We see in the energy sector an industrial price war ,the to high salaries ' eats ' down the company margins !
It is better to plan industrial production directly salary-bodies free ,if possible 100% by robotic machines and in 24/365 work capacity use,low taxes and costs : on ship-factories in international water !
Science : fiction or reality !?
An example : https://en.m.wikipedia.org/wiki/Colomban_Cri-cri
Powerplant: 2 × JPX PUL 212 single-cylinder piston engines, 11 kW (15 hp) each
nominal -peak- 11 KW combustion engine equals nominal 5 KW electric engine
2x 5 KW electric rotor/turbine/propeller drive
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20091130&CC=PT&NR=104078A&KC=A#
with average 2 x 5000 VA / 100 = 100 VA per hour flight drive consume !?
The poste #68 the shown 20 sqm cube/box/space heat energy need for the 0°C outside and wished average 20°C inside air temperature conditioning : 850 W by thermic insulation Koefficient 1,0 ,taking the CIAM conference 1929 social and architectural size result for a 4 capita family :
9 sqm each and 30,5 sqm common social area ( bath,kitchen,living room,hall ) = 66,5 sqm
66,5/20 = 3,325 x 850 W ~ 2830 W heat energy demand per hour for 66,5 sqm area
this delivered by
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=16&ND=3&adjacent=true&locale=en_EP&FT=D&date=19881020&CC=WO&NR=8808220A1&KC=A1#
https://worldwide.espacenet.com/publicationDetails/description?CC=WO&NR=8808220A1&KC=A1&FT=D&ND=3&date=19881020&DB=EPODOC&locale=en_EP#
    To clarify the operation of this embodiment according to the invention, the following dimensioning of the transformer windings is given using Figure 17 as an example, the iron cores being dimensioned in accordance with the manner usual for transformers:
    - winding 81: 1000 windings, 220 V/50 Hz, 5 A at full load;
    - winding 82: 1 winding, 5000 A;
    - winding 84: 1000 windings, 5000 A; - winding 85: 1100 windings, 4500 A, 220 V/50 Hz.
From the above example it is evident that, with a coil 82 having 5000 ampere windings, a flux variation of 5000000 ampere windings can be generated with the superconducting coil 84. Accordingly, a generated power of 990 kW can be drawn from the terminals 89 for a power supplied to the connecting terminals 88 of 1 . 1 kW, and this corresponds to a power gain of approximately a factor of 1000.   In the variant indicated in Figure 18 of this fourth embodiment, a two-phase system has been assumed. In a further variant of this embodiment, the latter can also be constructed according to a three-phase system. In the above described variant, a mains frequency of 50 Hz has also been assumed. These embodiments may, however, also be used for other frequencies. ......"
Acceleration factor,input/output multiplicator : Ampere-turns x Ampere-windings
But in one 1/100 output size ,990 KW/100 = 9,9 KW output by 1,1 KW/100 = 11 W input
enough for the 66,5 sqm social 4-capita-household area air condition demand about 2,83 KWh ,
with physical
    - winding 81: 1000 windings, 220 V/50 Hz, 5 A at full load;/ 100 = 220 V x 0,05 A = 11 VA input
Alternatively :
https://patents.google.com/patent/US8847720B2/en
Room heating by IR devices can be in the KHz/MHz em spectrum !
'thermotexx' resonator by Dr.Helmut Reichelt et.al. in the THz emission spectrum ,input ?
When 50/60 Hz equals 3000/3600 RPM ,1 KHz = 60 000 RPM ,1 MHz = 60 000 000 RPM ,1 GHz = 60 000 000 000 RPM , 1 THz = 60 000 000 000 000 RPM ,in em spectrum called ' cycles/swings' ,Ampere-turns or Hertzian cycle/-s
The physical ideal ' overunity-device' is as wave-/frequency-/time-/signal-/pulse-generator a ' static device' ,MEG like.
1 Hertzian cycle represented by 2 signals( or 2 e-m pulses )  input .   50/60 Hz = 100/120 SPM,S= Signals
( per pole ,half-cycle,1 signal)
In a scientifical society with lunar and planet Mars colony planning there are not technical border to include !
The importance,actually unknown,by the above shown Ferreira/Envez /Zielinski/Goldbaum how many ' shots/impulses' ' survives' a.capacitive coils or b.superconductive coils = functional device use-/life-time !?
Here in overunity.com are many ' pseudo-gi(g)ants' ,in german : "Maulhelden",from " idea-plan-company : success- error-chaotic fiasco"
the last 30 years " green energy/economy" tells much :
https://www.buch-der-synergie.de/
Thousands of industrial  trials,real and professional and under all comercial conditions !
Billions invested ! And losed/losted !
Under-/over-estimate number/-s for example ball-bearings with 24/365 permanent work :
20 000 000 Rotations lifetime (warranted) ,seems much
20 000 000 / 60 RPM /60 M(inutes) = 5 555 hours work ,compared : 1 year has 8766 hours
The above Ferreira/Envez 5 KW motor rotor average RPM : 18 000 = 1 080 000 RPH
= 25 920 000 RPD(ay) ,we see ' 20 000 000 rotations ' are not much as ' lifetime' !
Probably important as short-life but energetic economical rocket/torpedo drive !?
             Simple physics balance :
What do You know about the growing size from Wind-Generator rotor ,100 meters and more (on-/off-shore) ?Alternatively : lower rotor-size,higher RPM .
Logical !
Probably an AI-plan2reality administration system is more serious than to work with such reality-incompetente pseudo-professional  crowed !
Not to please,to dictate !
Here,forum inside : Netiquete ( to be nice,polite,'friendly') roule/ethics ,in real world : applied barrier destroy/killer instinct !
wmbr
OCWL
