Creating TPU Steven_Mark
Started by crashangel, September 06, 2019, 02:25:16 AM
crashangel
Guys, I was reading all these documents that you shared here and once again I am thinking of rebuilding my device before starting to perform the control tests ... I saw that SM probably used iron wires on their TPU. .. I am thinking of doing this that surely will get a kick with higher powers and it seems that this was what gave that feeling of movement like a sander as I read in one of the previous posts ...
Now my question is, did SM use iron wire on the 3 pickup coils and the 3 controller coils?
Would those stainless steel electric wire fence reels fit this?
Could this be a plausible path?  ::)
e2matrix
I think you'd probably want iron wire.   I heard of using coated green garden wire (often used for tying up plants).  I'd avoid stainless steel wire which is mostly non-magnetic.
Turbo
Quote from: crashangel on October 01, 2019, 05:57:37 AM
Iron wire in the early models.
It's better if you first find out why and how before continue because like i said you have to use meaning in your research.
You have to know why you do what you do.
Otherwise its just one more useless coil and we wrapped so many of them.
If you use this type of wire the specs are as follows:
There are four naturally occurring isotopes of iron:
Isotope | Abundance
54Fe, 5.845%
56Fe, 91.754%
57Fe, 2.119%
58Fe, 0.282%
amu or atomic mass unit:
Iron-54 has a mass of 54 amu, Iron-56 is 56 amu, Iron-57 is 57 amu, and iron-58 is 58 amu.
onepower
I think SM nailed it when he said nobody is going to throw this together and make it work without first having some idea how it could work conceptually.
SM made some comments I thought were interesting
QuoteThe kick is universally atributed to the earth's magnetc feld.  OK the point is; YOU CAN GET SOME ENERGY OUT OF THE EARTH!  Next point; YOU CAN DO SOMETHING VERY SIMPLE WITH A WIRE TO SHOW THIS.
I would simply rephrase what SM said -- "YOU CAN DO SOMETHING VERY SIMPLE WITH A WIRE TO GET SOME ENERGY OUT OF THE EARTH".
This was interesting however I also remember SM mentioning that the control input and the collector output both showed up on the load. So the input does something to the collectors then both the input and collector output drive the load?. To many I suspect this means very little as normally they believe the input is somehow consumed but here SM implies it is not.
If A is the input and B is the collector output then the power output to the load is actually A+B. If the output is A+B then why not use B to power the load and simply recycle A back to the input to repeat the next cycle?. As such it would seem to me that the logical place to start would be to 1) figure out how to get some energy from the Earth with a wire and 2) how to use the input in such a way that it always adds to the output.
Jeg
Quote from: onepower on October 01, 2019, 06:07:23 PM
Hi 1pwr
It might be something simple like in Floyd's drawing.
