Creating TPU Steven_Mark
Started by crashangel, September 06, 2019, 02:25:16 AM
Turbo
Quote from: rensseak on September 24, 2019, 12:49:00 PM
I will not remove it but for sure is this picture where made in CA.
https://postimg.cc/sBGf5hDC
So what do you want to say exactly ?
It is from California so it has to be correct ?
Clearly it is wrong on multiple levels.
Who made it doesn't change anything about that.
Are you trying to say Steven made those ?
Why would he wrap something that contradicts it's own writings ?
I don't buy it.
And it doesn't matter at this point in time.
You could probably get some juice out of it if you use the control winding as a yoke and slam the collector with the correct atomic frequency.
rensseak
Do you think he would cut it so easy with a jigsaw if made in that way? And does it look like to rings seen in the open TPUs?
Turbo
Quote from: rensseak on September 24, 2019, 01:15:56 PM
This is not the correct place for speculation maybe that other board is ?
'looks like' this and 'looks like' that just isn't going to do it.
That has proven to be an endless loop.
I just wrote down exactly how its done.
And its very easy to verify my words.
So besides the fact that speculation leads nowhere, it isn't even necessary.
I already posted the solution way back in 2012
But it was rather quickly buried under a flood of garbage and speculation.
I walked away.
Seven years later i checked the OU.com site and i noticed that member crashangel was looking for info on the matter.
So i decided to put in some more words, to try and help, but here we are, once more ready to be buried.
I just hope that maybe some people will see the light and read back some of my posts and experience the AH-HA ! moment they search for and so desperately need to push them in the right direction.
I also hope that they won't get scared away, when they realize the true colors of the technology and will approach it with caution.
forest
Turbo
Can you be precise in your statements ? Can you correct me ?
1) 3 control coils one on top of the other (circular rings each of smaller diameter) are used to create effect of radiation of "particles" which Otto described
2) 3 collector coils , each one around one control coil
3)  one collector coil on everything
collector coils are output coils and catch "particles"
is that the correct description ?
Jeg
Turbo
Do you know what is the material that releases the electrons in sm's devices? A closed loop iron wire in parallel in between the collectors? Like in the photo above?
