Creating TPU Steven_Mark
Started by crashangel, September 06, 2019, 02:25:16 AM
0 Members and 17 Guests are viewing this topic.
WhatIsIt
TPU Inogda1.part 3
https://www.youtube.com/watch?v=XRB-NSczJak
Here is translation of online youtube speech to text converter of that video,
which is probably very inacurate, but can give some sound to silence.
that is, in theory, these programs can be made a little shorter shorter and thicker
Well, now the most important thing is that everyone has fun.
300 W lamp seriously so that you don't always find it on sale.
Yes, the point is not the current consumption and voltage of the digital circuitry of the digital part of Semenov's policy management, but it actually turns out to be slightly less.
Well, everything works before and let's go.
dad went on feces went on darling account without setting up without anything and with mine what we use in general the most reliable testimony is obtained just by measuring the current on the wire the current clamps that measure and direct and alternating current is that we end up with 12V from the battery 4 ampere hours a hole for the lamp to work 300 Watt the lamp is slightly brighter the choice of heat is released more than it shines clearly hot.
But you're already in the woods, well, you're just a friend, she can Denis registan can be a hotline hot.
Well then thinks to Each generator that creates a non-555 cafe capacitor 12495 its position is approximate, where everything comes more than that.
What needs to be done in the lines so that you don't have to look for the resonance of the Nice copper;
exactly the same thing, two floors two rings Check this out seriously.
Well, who knows it is serious and not serious, an expensive condition, we did not try to overclock the maximum voltage here the current source works what you need to study for the active load the lamp is 300 watts see amperes 0,1 A hell just shit the lamp power is hot and when consumed 0,1 A it's fucked up.
This is Stephen Mark sure, water of the community you want to show the displacement of the door I want here the displacement is still here to catch.
So you just went to grow to watch nothing at all.
On what kind of radio you can be so beautiful it was written there very much catch tuning as a radio.
Movie fucking 0 you caught 0,1
that's fucking 0 amp
fucking at 10 amperes the lamp is on Ahuyet you can keep negative you can't keep something somewhere fucking 0 amperes
0 ampere really
fucking where we have the Earth
wait
Wait the Earth should be.
This is what they wanted to see on the shutters, fucking zeros, fucking photos.
Take off please who won there take off now it stretched it what happens on the shutters of field workers clearly filmed everything the best work on lyrics that wake up under the contract.
Now wait takes off, fucking that going on the arrow.
Yes, fuck, fucked up where the Earth is closer.
And how OSU Earth look what's going on in the drain like this and so it's really cool and you don't need a divider to school now you need to turn on the picture on the drain what's going on here now we have 100 volts in the cell and time is worth fucking the sheets will need 5 microseconds further each phase will itself be done by 1 phase.
Yes all day will be the same.
What you need to get so much.
Now if we start to stretch all this, we see here, that's what it is all the shock impulse that provoke the whole process.
Yes, pulling up as best as possible.
Again, 100 volts in the cell and the same 5 microseconds, well, there are already 0.5 you are already unfastened?
You can make it 560 like this.
Like this will only have a shock Impulse arrive on the shutter when the device is working this goes far does not show that 0 amperes we are still limper upset me nothing will change there 0 amperes
always 0 ampere outsider shutter full description.
Well, let's raise it so that it is better to see what tomorrow plans are to adjust; the signal on the shutter; the shutter ringing; these are generally positive characteristics in this case, transistors do not need to be shielded in what colors I think enough again, we have 0 amperes, once again the lamp glows again, heating says my dick, hold your hands and there it goes the power supply of the digital part itself.
We draw conclusions braking and wait until that doesn't remove the most interesting moments.
everyone can judge the current consumption by the spark of other devices better and more precisely.
I can't show anyone who saw device.
Turned on
turned on and off
turned on
turned off
Olympia 60 amp in the tap beats recklessly as if she doesn't have a real fuck CT scans are not well,
so that part of the brand new there, he was looking to tweak somewhere a0.
Well, at least it pops up while I'm tuning,
But here is Ber dimming the diode lamp, turn here and then here you can hear the gap that when I jerk.
Well, I don't really need to see anything.
Well, the whole course has already ended.
Toolofcortex
Keep an open mind.
Inogda1 was also seeking for explanations.
This translation sounds like the rambling of confused man. ;D
This reminds me of the time when I brought russian videos to somebody.
Only for it to be useless...
Go read Chris Sykes, now this goes back to SM a bit and the node area.
He recapped this thread at the end, go to thr total end.
http://aboveunity.com/thread/non-inductive-experiment/
Then, I want you to confirm me this patent app and its coil configuration, iN FIG 10.
http://www.rexresearch.com/craig/craig.htm
https://www.youtube.com/watch?v=wpAA3qeOYiI
Bismuth will bend and curl the field of 6 coils (bucking coils I think), and from the opposing current there will be a middle sonze when both bismuth push back, and it will be curled. A computer could show us how it looks like.
Now its weird, sometimes I wonder if these pulse things dont make the field come back across and block wall momentarily, whats the rule when you have a large clred up field and you pulse real hard. would this be slower to react since its so large??
Toolofcortex
http://www.aboveunity.com/thread/current-and-voltage-amplification-key-to-energy-machines/
This will be my last post lnking to this site.
Bathe yourself in the knowledge and come up with a coil, and when you do, bring it here.
I collect all coils. I collect collector coils you can say. The collector of collectors.
Through electronic wizardry, A hustler can hack the game, and collect power.
Also, you still havent zoomed in on the dissasembly of Akula's TPU, bring that too, while you're at it.
One step at a time, draw it. Bring that here, WORK! It will be wort it, I also have my collection of hardly acquired designs.
ramset
You have knowledge that can save lives and extinctions and our planet and you make excuses for with holding this Knowledge
How do you put your head on the pillow at night...how many must Die ? how many species must pass..etc etc
In 2015 The ,"above" man showed up with 1.7 OU claim schematics and all...everybody who replicated had no success [sounds like Whatisit above too [no success ??]
Then came flame wars ...everybody here was Bad guy ,every rock had Bad guy hiding behind it even many Times Calling Stefan evil something or other ...all Kinds of anti Semite stuff Mixed in[Myself born to Christian Parents From NYC has me reborn as Jewish..with much Evil Jewish writings/claims mixed in etc etc
Much Hate from this guy ,all his nasty comments got him banned [broke German laws no choice]
then he had Russian friend here changing posts [and bragging about hacking skills too] and inserting banned persons new posts for several weeks...
he says he was not hacker [just benefited] and now makes more words around whole incident..?
Hacker sent Torrid PMs re Wesley and Jewish etc etc [nauseating stuff..
and now you bring him again here for reboot ...Five plus years....How about enuff finger pointing and make believe "the Bad guys made me stop sharing My OU circuit"
how about post all his claims for scrutinypost his site as long as you wish [if science/experiments ..not excuses and finger pointing nonsense
Because I have spoken to no man anywhere who found OU in his first claim.
dozens and dozens years and years...tonnes of experiments ..
this forum is open source {i am quite certain we would never see you again Tool if you find OU here.
you path has been made very clear..
does not matter ,people should know what you are and "so be it" [at least you tell them
so Post OU experiments/claims for replication   till your fingers bleed
enuff excuses ,the world needs this ...desperately.
plenty good open source men toiling here and elsewhere...
no excuses from them..you want to change the world Be that change
Thanks Grandma
Toolofcortex
You are so so lost... I simply am in love with Shapovalov.
The men should be fit and hard fighting tennis players. Did I mention a race ?
I thank all the Einsteins and such... But its time to move on.
It should be adjusted, so that every representative is there.
And there should be AAA females also, scientists. Who studies hard? Did I mention a race ?
What are we gonna get with your idea 100 years from now?
Do you want a Weinstein running the show or a Shapovalov running the show? Whos mad because nobody wants to touch his pipi? Whos got an abundance of offers to touch his pipi and needs to sort it out?
Yeah its that simple, the only reason why people push themselves is so they can mate. So now when everything is run by robots basically and there is OU what comes next?
Shouldnt we jsut say to hell with this and put everybody's best cards on the table and reshuffle?
Some sort of Harmony, in the contuinity of a permanently relaxed super-race?
