Wireless energy transfer experiments ,Builders board
Started by ramset, September 18, 2019, 09:15:01 AM
stivep
That  depends from  what  is your  application.
If you want to send energy  from point  A to  point  B at some distance  than
due to impedance  mismatch it is easy  to  lose  these 300mW
Your signal generator by  itself may  have that power level  of  power  at its  output as  well ....so  what do  you need  the  500 series amplifier for?
In any other case your generator can be  connected to any external  amplifier having much bigger  power at desired frequency and is available on Ebay.
QuoteEach tesla coil is your amplifier and transmitter.
NO   IT IS NOT.
Tesla  coil  is  only changing   voltage   from  low to higher but power level is  never amplified.!!
If you deliver  300MmW to  Tesla coil primary at 1V    where  primary  is 1 wind and  secondary  is 1000  winds  than you will get at secondary  1000V
but overall power will  be 300mW    minus  the  losses.  !!!
Using terminology -  "Voltage amplification"  may  be  not   quite  accurate.
You  amplifying nothing
You just losing
Basic rule is:
-  The  power at input is always bigger than  power at   output!!!
so  Tesla Coil  as air  coupled  transformer can  be  called "LOSER"
as opposite to "gainer"
In regards to  Tesla Coil being called Transmitter?
Yes it transmits    something....
but that depends from   application
No it
does  not transmit/ doesn't radiate  in  Far filed ....but that depends from   application
Wesley
r2fpl
The basis of the principle of signal transmission is to generate an RF signal which is a high frequency electromagnetic wave, so why do you think that the Tesla coil itself is not an amplifier, let alone a transmitter? It amplifies by increasing the amplitude or is that not what the amplifiers are about?
stivep
Quote from: r2fpl on October 08, 2019, 10:58:44 AM
Amplifier:
Quoteelectronic device that can increase the power of a signal (a time-varying voltage or current)
https://en.wikipedia.org/wiki/Amplifier
Tesla  Coil is never amplifying  power of signal.
Amplification  of  power must be seen  as  done at cost of  someone who is  giving you needed  energy for it.
(and  that can be  your   own pocket when you pay the bill  for electricity)
the  very concept of free energy is to  find this someone who pays  for it and than  you  pay nothing.
e.g wind,  solar,  thermal, or energy from Schumann waveguide
Wesley
r2fpl
This is obvious but I don't think we've understood each other about the word amplifier.
I meant an amplifier in the sense of a power amplifier, e.g. for a music.
onepower
Wesley
Quotehttps://en.wikipedia.org/wiki/Amplifier
the  very concept of free energy is to  find this someone who pays  for it and  you  pay nothing.
Condenser: A capacitor (originally known as a condenser) is a passive two-terminal electrical component used to store energy electrostatically in an electric field.
In the past, the Condenser was also know to be an active component condensing or concentrating an electric fluid. In fact one can still use a wire antenna, condenser, inductor and a rectifier to condense electrical atmospheric energy. Some say this is just a receiver for Hertzian waves however it is also known in the art to be able to condense or concentrate electrical energy like an amplifier. However in the case of the condenser we are not amplifying an Electro-Magnetic signal but separating and concentrating electrical charges as energy.
Passive components are well enough however the real action is in active or dynamic components.
