Wireless energy transfer experiments ,Builders board
Started by ramset, September 18, 2019, 09:15:01 AM
Light
comment of Igor Moroz deleted  as inflammatory  aggressive and inconsistent with the subject of this forum.
But I'm glad that  "some  Russians" reacted this way.
Russia can not exist in its current form if  any publication  in this area is replicated into  working device.
Wesley
stivep
PART 3 :
All credits  paid to:
-Dr.James Corum
- Kenneth Corum
- Gary Peterson
- Dr Hans
- Dr Roy
Thank you to all mentioned above contributors to the general knowledge, whose position was  supporting,
contradicting or correcting  presented  phenomena, phenomena in question and described processes.
TRANSMITTER
Two different forms of Transmitter:
Both of them use slow wave helical resonator L1
The green color transmitter L1 is connected to top capacitor T1
and to the earth ground .
The red color transmitter  uses capacitive reactive connection to the ground through Cb
That explains Tariel Kapanadze device as working  with  or without the ground wire.
That is also in line with Dr James Corum (Viziv) patents.
Virtual "capacitor " Cb  is  formed  between T2 and  earth-the lossy conductive medium
Wesley
stivep
Be careful here before you click on this link:
there was warning saying that  certificate of this article is invalid or expired.
This article is not  directly related to  my current material
posted here .
But it talks  about  polarization  that will be discussed  here as well.
so why it is important?
High-power phase shifter that can on-line adjust the transmit phase of high-power at microwave (HPM) .
the only difference here  of great interest will be:
High-power phase shifter that can on-line adjust the transmit phase of high-power at LF or ULF frequencies.
so the phenomena is important  as it applies to any frequency .
After I clicked on this link and accepted the risk  around 1211kbts of data was tied to be send to Chinese or Russians..
I pushed kill switch and changed  VPN location.
No more tracking was  happening.
https://piers.org/pierspublications/PIERS2014GuangzhouProceedings02.pdf
QuoteAbstract : In this paper, we proposed a type of all-dielectric metamaterial(ADM) with quasi-continuous structure,
which can inspire quasi-continuous electric and magnetic responses to ac-quire left-handed properties in free space.
The proposed model utilizing dielectric rods and cubes as sub-wavelength inclusions.
A two dimensional polarization independent left-handedness can be achieved with the frequencies at C band.
The rods resonant under characteristic modes can generate negative permittivity and permeability,
whereas the cubes are used in the non-resonant ]modes to assure the continuity of the displacement currents in dielectric inclusions.
The simultaneously double negative properties can be interpreted by electric and magnetic fields distributions of the dielectric
inclusions near 7.6 GHz under normal incidence with polarization angle 45
further study on transmission spectra and effective
[/font]
refractive indexes of the model with different polarization angles shows that the left-handed property is insensitive to different
polarization angles due to theπ 2 rotation symmetry of the ADM.
The proposed ADM can be easily realized at infrared and optical frequencies with dielectric inclusions.
Wesley
stivep
PART 4:
-Dr.James Corum
- Kenneth Corum
- Gary Peterson
- Dr Hans
- Dr Roy
Practical  information about constructing Transmitter receiver pair for transmission energy from point A to point B
Note:
Working device made by me (didn't work in my place at that time) and pushed to work  by Dr Hans may be published  as well.
The device  is:
1. extracting energy from Schumann  waveguide
2. uses only one Tesla coil acting as receiver.
3. this energy exists in the interface earth air  in form of surface wave known as Zenneck Wave.
4. the level of that energy is varying based on energy fluctuation in Schumann waveguide.
5. that energy  enters  the  interface  at Brewster Angle .
6. Tariel Kapanadze device  is likely the best and the most advanced  form of such device,
   but Tariel doesn't have any idea how the device works and what  physical phenomena is taking place there.
   He was just able to make it work.
a. technology of  Dr James Corum is just  simple transmission of energy from A to B but uses exactly the same
    phenomena as Tariel Kapanadze. The only difference is that  Dr Corum  uses transmitter receiver pair being separated
    at some distance-preferably unlimited around the earth.
b. training  with Dr Corum A to B transmission is the must!!!
    -unless someone will be that lucky as Tariel Kapanadze to just get it right , for the first try.
c. this is not the toy and it is not any kind  of  Russian fake, however Russia may collapse as a first after  working device is
    available for wide replication.
Quote: of  practical  application material:
This  is not my text and article or quote  is not is  mine
QuoteA type-one Tesla transmitter.  The resonator has a 7:1 aspect ratio,
which is the same as one of the experimental coil forms that Tesla used in Colorado Springs.
With the door-knob topload it resonates at about 185 kHz.  An elevated 23" diameter aluminum
disk brings the resonant frequency down to about 123 kHz or lower.
Wesley
stivep
PART 4a :
-Dr.James Corum
- Kenneth Corum
- Gary Peterson
- Dr Hans
- Dr Roy
The text  and/or posted material is not mine :)
Primary
coil form (spool): upper portion of a 5-gallon plastic pail
Diameter: 11.5"
Length: 2.125"
Wire size: AWG #14, type MTW  THWN  THHN  AWM 600 volt
Turns: 18
Winding length: 2.125"
Secondary
Coil form: 1/8"+ cardboard cylinder with 3/32" acrylic ends, with a few light coats of polyurethane finish
     (Grace Ice & Water Shield cylinder)
Diameter: 5.3125"
Length: 38"
Wire size: AWG #24
Turns: 1740
Winding length: 37.5"
Inductance: 54.6 mH
Resistance: 72.7 ohms
Height of bottom turn above ground: 18" + 6" (pallet height) = 24"
Elevated terminal
Aluminum disk
Diameter: 23"
Thickness: 0.125"
Height above top turn: 3' 4.5"
Aluminum duct
Diameter: 3.25"
Overall diameter: 29.5"
Ground terminal
Copper bonded steel rod: 5/8" x 8', 2 with 8" spacing, driven into the water table at a depth of approximately 4' below grade
Connecting wire: 14' AWG #10 (stranded) + 21.5' AWG #16 cord
NOTE:
mast must be telescopic and must allow to adjust  the position of the top capacitor Up/Down !!
Wesley
