Wireless energy transfer experiments ,Builders board
Started by ramset, September 18, 2019, 09:15:01 AM
stivep
Quote from: pix on June 29, 2023, 07:44:15 AM
Side question to you Stivep.
How Tesla receiver can efficiently tap to Shuman wave guide frequency as they are few Hz and even large Tesla resonator work in dozens kHZ range?
Cheers,
Pix
Schumann discovered resonances  of the electromagnetic energy in  space between ionosphere and air( - the boundaries)
This  space forms a waveguide .
~7.85Hz is a fundamental frequency of Schumann resonance .
It is a minuscule amount of energy
-in the free space per  square m/ ft. or if our antenna is at
placed  at any point of the earth surface(  the boundary of that waveguide)
We can also look at it from the perspective of  effects it can cause:
-one single Lightning can trigger  lightning avalanche  around the world.
https://www.nasa.gov/mission_pages/sunearth/news/gallery/schumann-resonance.html
So how much of energy is needed to  create  lighting strike avalanche? hm? ??? ?
looks like a lot  Yes? ??? ?
We may also think how much energy in total is in Schuman resonance.
https://agupubs.onlinelibrary.wiley.com/doi/epdf/10.1029/98JD02648
Mechanism of electromagnetic wave propagation:
For typical electromagnetic wave in  -free space . Inverse-square_law   applies.
it means : Any point source   (tx transmitter)  spreads its influence (electromagnetic wave) equally in all directions without a limit to its range obeys the. inverse square law
An analogy:
It is like giving equally to the crowd around  $10millions - everyone gets  just a minuscule amount of $.
But if you direct  it into one direction the receiver Rx can see huge amount of it or amount of energy.
So energy of  2,000 thunderstorms that roll over Earth, producing some 50 flashes of lightning every second
can be  calculated  as certain amount of electromagnetic energy produced by it in total.
Than certain percent of it  hits the  earth /air interface -waveguide at the complex Brewster Angle and we can sense it or receive it.
Earth as a lossy conductor is a boundary of the second waveguide .
The typical way for us to measure or sense energy in the waveguide is to immerse probe in side of waveguide- like your finger  in the water
Our Tesla coil is doing this job
You are immersed in the waveguide  while standing on earth (-the one of the two  boundaries of  earth/ionosphere  Schuman waveguide) so is Tesla coil instead of you.
Earth is also  the boundary of  another waveguide called interface  Earth/air).  For a probe to be immersed in that second 2D waveguide you need
special condition -so is Tesla coil instead.
Quote from: stivep on June 28, 2023, 06:41:31 PM
Part4: Summary:
Because - the space between Ionosphere and  Earth is /makes( Schumann waveguide)
and 2D space between  air and earth is another  waveguide than  we may try to  move some  energy e.g.
-energy originated  by lightning strike, move to that second waveguide and  than extract it from there and use it for ourselves..
If we are able to do it  than we have  our electrical Energy For Free
In reality  we physically  don't need to do anything. If that energy lands in our interface  it is ready to use  for us.
Every lightning  is contributing  every second to it.
Wesley
stivep
Quote from: seychelles on July 03, 2023, 12:16:39 AM
Not wireless but one wire still very interested.
https://www.youtube.com/watch?v=TToFYXS3niM
Although is is an  excellent  comment- it should be here after all parts of my  educational material for experimenters is finished   I'm going to respond to this in my   general conversation topic.
https://overunity.com/17735/kapanadze-and-other-fe-discussion/msg579709/#msg579709
Wesley
dsquared18
seychelles
THE PRIMARY OF THE TESLA COIL SHOULD BE MAKE OF A COPPER TUBE FILL WITH LOW PRESSURE CONDUCTIVE GAS.
SUCH AS ARGON  AND NEON. FROM THE ETHERIC NET.
