This forum is turning into trash
Started by ARMCORTEX, September 25, 2019, 04:33:34 PM
skywatcher
Quote from: DavidWolff on November 02, 2019, 10:21:06 AM
Skywatcher you sound very angry are you angry? For an educational experiance  lookup, Moray King on youtube and learn how the masters got things to work!
as you wont find much in this thread as folk ether want to bull shit or ridicule others and think about this what's the difference with
and between 50 or 60 Hz and 50 or 60 Khz  the number of transitions in between each zero-crossing  point node it produces more energy
so what's the difference with that and zero-point energy the same thing atc a far greater frequency, now find somewhere to get it from, answer the fluctuating
background of cosmic space that bombards our planet randomly collection problem and you're there. 8) 8)
Dave Knowmore
Angry ?  Maybe a little bit...  angry about people who pretend to know or have something, but when you ask concrete questions you don't get concrete answers... angry about all the stupid stuff which is posted over and over again, where it is obvious that it can not work... angry about all the scammers etc...
We should focus on reliable information which can actually be used by others. If you have something, please post it. But please post everything, not only some vague hints with some 'if i post more some men in black will come and take me' nonsense.
You understand what i mean ?
onepower
skywatcher
QuoteSo if Mr. Moray spent 30 years of his life to develop a working device, and if this was successful, where are his devices now ?
Was nobody else able to replicate them ?
Did he fail to document everything and took his secrets into his grave ?
T.H.Moray, like many inventors got involved with business people and investors. Later after going public he received death threats almost daily and was even shot by someone. Moray did document his work and wrote a great deal of literature regarding most of it however he did not disclose the critical details allowing it to be replicated.
T.H.Moray's work was carried on by Paulo & Alexandra Correa with there research of PAGD (Pulsed Abnormal Glow Discharges).
http://www.rexresearch.com/correa/correa.htm
If your looking for a starting point to research FE and build something this is by far the best place to start. Almost all credible FE devices always come full circle back to HV and plasma physics. As well the Correa's work is by far, bar none, the most well documented research you will find anywhere on the internet.
In my opinion, because of the sheer number of witnesses and countless tests done by qualified experts this device was real. Of my list of FE devices I believe were genuine and credible T.H.Moray is in the top 3. He is also one of the few inventors who wrote a great deal of literature explaining in detail how he thought the device worked and more important where he thought the energy came from. In this respect, he is at the top of the list and required reading in my opinion.
Turbo
Quote from: onepower on November 02, 2019, 03:20:08 PM
skywatcher
Well i build a PAGD way back in 2009.
I just realized that its already 10 years ago.
And even though you are right it could be the best documented device or process, it does not state anything about the source of the excess energy.
This is the same for Moray and Gray and many more, sure some have a theory but that is what anyone would expect by analyzing the set up.
So i will tell you my findings on that PAGD.
The electrodes deteriorated and it would only run for a limited amount of time before they need a replacement.
I firmly believe that the electrodes undergo a nuclear transmutation thereby releasing energy.
This means they or the material itself is the fuel that get's 'burned'
And the energy that is released is then channeled or focused by the strong electric field component.
It could be a crude way and there might be more efficient way's to generate the same effects.
And it is known that elements can undergo transmutation when they are bombarded by high energetic particles of a specific energy level.
That is certainly at work in that tube and you can see that by studying the discharge curve.
Tesla, Edwin Gray, Correia/Chukanov, T. H.  Moray : themes from 2004 and earlier
Can their inventions be same cheap per KWh-electricity like :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=5&ND=3&adjacent=true&locale=en_EP&FT=D&date=19280203&CC=FR&NR=633752A&KC=A#
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20121009&CC=US&NR=8283799B1&KC=B1#
2 €cents/KWh. ! But uncontroled : over - and/or under Wh or Wp demand  !
Strategy "Term": Balance of Power ,not to less/to much ,but : perfect. : 100% demand serving !
A perfect off-grid organized system : 5 €cents/KWh ,global average. !
The last real barrier: high charge cycles battery/supercapacitor costs
2019 progress news :
https://www.intelligentliving.co/stanfords-cheap-bendable-aluminum-battery-charges-minute/
https://www.hotspotenergy.com/solar-batteries/price-list.php2005 Carbon AGM battery " patented or publicated "? + 17 or + 20 years grant validation   ?Next worldwide faster battery price decrease.phase !
Accelerated by supercapacitor market  entree with 10000 charge cycles and 125 US$/KWh endconsumer price. !
onepower
Turbo
QuoteWell i build a PAGD way back in 2009.
And even though you are right it could be the best documented device or process, it does not state anything about the source of the excess energy.This is the same for Moray and Gray and many more, sure some have a theory but that is what anyone would expect by analyzing the set up.
Time sure flies and I really started getting into FE around 2009.
QuoteSo i will tell you my findings on that PAGD.
Moray and Tesla mentioned Cosmic Energy as the source however few people could connect the dots. You see Cosmic Energy is the primary cause of all oscillations in matter, which causes the field/binding forces in matter, which when disturbed through fission-fusion-transmutation liberates said energy in matter. As such most theories are correct to a certain degree it's just that few could trace the primary cause of the energy back to the external environment... Cosmic Energy. We know this is true because the same effects which liberate energy from matter also cause matter to interact with the environment ie. anti-gravity effects. Ergo, it cannot simply be "nuclear" in origin because nuclear relating specifically to the atom cannot produce anti-gravity effects in itself.
As well every true genius involved in FE followed a specific learning curve. First FE effects, then FE devices, then the transmutation of matter and then a select few graduated to anti-gravity devices and other external effects such as weather modification. Therefore there must be a direct link between FE and the external environment.
QuoteAnd the energy that is released is then channeled or focused by the strong electric field component.
I suspect there are many ways of releasing the energy latent in matter and we need to get past the primitive notions of burning, consuming or using things up. The universe is in perpetual motion on every level, motion is energy, therefore all we need to do is transform or convert this motion/energy into a more suitable form of motion/energy.
