This forum is turning into trash
Started by ARMCORTEX, September 25, 2019, 04:33:34 PM
http://www.bticcs.com/pub.htm
"CCS a New Technology for the Automatic Charge Controle of Rechargeable Batteries  "
Entering E. : 1:3 duty cycle/factor = 1:9
Now the question : really " lost" or
for appropriate use a solution :
"power saving " and coefficient of performance improvement !?
Pulse power motor re-/charge process  ! INSTEAD BATTERY CAPACITOR
http://guns.connect.fi/innoplaza/energy/story/Kanarev/
Let us declare him "as worst case":  a "charlatan" ,
"ON THE WAY TO PULSE POWER ENGINEERING"
but where is the fault in calculation(= "contradictions" !)  that
pulse voltage x pulse current = 15000 Watt output
by average voltage x average current 1,5 Watt input
Amplitude : 10000 = ten thousand times.           Max/Min = less               Min/Max= more
rakarskiy
Quote from: lancaIV on November 06, 2019, 08:29:40 AM
Oddly enough, the inspector came, measured his thermal system with a pulsed plasma heater, made sure that the efficiency was greater than one, and left. Confirm and impossible to destroy ... you joined in, too. With Boris Z. the motor-generator works in the same way.  Came looked and is gone.
What's the catch? He doesn't believe like a parasite. Parasite counts "the number", Kanarev produces a "result". In the end, the parasite is a loser and " bankrupt"
https://www.youtube.com/watch?v=Py3eYmee-Ew
https://www.youtube.com/watch?v=HxbtVaiXilg
rakarsky,Professor = teacher Kanarev : numbers are also his world ,not only physical experiments. !
15000 Wpeak x triangle pulse form (0,5) x pulse duration 0,00014 sec ~ 1 Waverage. = UNITY
3600 Ws = 1 Wh = UNITY
         Important are the 3x measurements contradictions !
http://rexresearch.com/kanarev2/kanarevpulsemtr.htm
" ....... power definition by WATT : Watt is work done per second by current and voltage continuously.   ....."
But there are, beside power input controle ( stepper motor technology/ Nola et cet.), the gains by displacement current to magnetic force use ( capacitor)  and the mechanical pull force by +/- magnets repulsion( JLNaudinds push&pull demonstration)  !
Number-errors :
to create energy storage devices which demonstrate energy conversion characteristics well in excess of gasoline
[ 650 watt hours /kilo]
"ucrainian gasoline" ?
Normal "gasoline" EURO-5  chemical energy content 11,57 KWh/Kilo
The me only known - theoretical -  storage device comparable to gasoline
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20021231&CC=US&NR=6501093B1&KC=B1#
There is nowhere worldwide somebody actually working on this level  !
Citing documents :
Dr. Lazarev
Nearing this level : http://energystoragereport.info/capacitor-sciences-thin-film-capacitor-technology/
2016 prediction : 250 Wh/Kg, later 1000 Wh/Kg,  +++ .........
bought by Blue Solution 2016, part from the french grouphttps://fr.m.wikipedia.org/wiki/Bollor%C3%A9_Investissement
rakarskiy
Quote from: lancaIV on November 07, 2019, 07:54:13 AM
So you're counting the entrance. Similar to their believes and Kanarev. I'm talking about the heat released by his plasma cell. The cost of one input, the heat dissipation of the other, is much greater than the cost of the input. That is-the total result of work (heat) is more than one. This point is demonstrated Kanarev, where the military evaluate the technique for its measurement.
You take a tube and a heat lamp :
how much energy per Liter water for 1° Celsius increase. ?
https://m.phys.org/news/2015-10-superconducting-ink-instantly.html
You take a tube, coat the outside with the Bolano coating, and a heat lamp :
how much energy per  liter water  for 1°C increase ?
http://free-energy.ws/samuel-freedman/
You take a tube,coat the outside with the Bolano coating,the inside coating with Freedmans " chemalloy" and a heat lamp :
how much energy per liter water for 1°C increase. ?
From 1 tube with diameter X to 10 capillar tubes with diameter 1/10 X, inside and outside coated :how much energy per liter water for 1° C increase  ?
quadrat centimeter tube surface/ ml water per second ratio = water stream velocity !
Next step :
The heat lamp consume controled by :
https://patents.google.com/patent/US5130608A/en
From 100 W lamp nominal electric consume the heat output in calories . ?
to   4 W lamp consume + 8 W Modul consume = 12 W consume the heat output. in calories ?
Next improvement :
Instead conventional lamp using graphite heat element :
https://patents.google.com/patent/US6741805B2/en
"... energy savings of up to about 75% are realized over conventionalheat elements... "
industrial heat lamps/bulbs Calori/Watt comparison. ?
Chemische Katalyse
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=11&ND=3&adjacent=true&locale=en_EP&FT=D&date=19760115&CC=DE&NR=2429086A1&KC=A1#
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=20161222&CC=DE&NR=112014006403A5&KC=A5#
+ low heat to kinetic energy ( rotations)  to generator or heat-electric foil
