Kromrey generator solved(?)
Started by pemox1, October 28, 2019, 09:42:39 AM
pemox1
It's a bit more tricky.
Generator should start with 24VDC. That's about 12A.
It is not self-starting and it needs probably about 200 Hz or more to produce enough induction-voltage to run with its own power.
One magnet has a holding-force of about 1kg. With 42 magnets, this is a lot of power to drive.
That's why I'm working on an Arduino-prog for starting and thyristors for the self-running-mode.
skywatcher
The patent is more than 50 years old. Enough time for lots of successful replications. Where are they ?
MasterPlaster
Quote from: skywatcher on January 02, 2020, 02:49:53 PM
Is this similar to motor used in Thailand to propel a motorbike?
There was a thread about it on OU.
pemox1
Here's a layout for selfrunning-mode.
I don't want to pull electrical power directly from the generator - like Kromrey did.
Think, it's better to take a belt and a (wind) generator - driven by the Kromrey-generator.
But I'm not really good with thyristors.     Can anyone find a mistake?
Relais 1 is only active in starting-mode.
Thyristor is a BT152.
sm0ky2
A reed switch placed in the right spot?
Adjusted location for timing
Should do the trick.
That circuit above seems overly complicated and would require power to operate it.
