My Ambient Powered AC Amplifier And Oscillator Square Wave Generator
Started by joellagace, November 24, 2019, 07:53:34 PM
joellagace
Well using my last idea, It definitely is self sustainable from the ambient and what not....
I'm able to produce and keep a 1kv spark gap circuit going like I expected I could, Driven from ambient power. It takes a moment to start then once spark starts it kicks the generator into high gear mode keeping the 1kv spark gap active for as long as I don't mess with it as you can see in the video, But it takes a moment when I do make an oops and after a few moments of in active I can start it up again once it has enough pre built up charge. So I  think I am going in the right direction.
Here is a video of my generator running on its own so far.
https://youtu.be/-grv14fkLXI
carbon sugar
great, did you put a ground connection to the coil? Or did you connect the ground to the input circuit? or both? Do you have an oscilloscope to see the signal? Does the coil I use transform the low frequency that enters, at high frequency at the output, will this circuit work for my coil? what do you think? thank you very much, very good your experiment
skywatcher
Quote from: joellagace on January 25, 2020, 08:38:53 PM
Very interesting... to make it clear once again: you don't need any input voltage now ?  Because in your 1st version there was an input.
What about the 'antenna' ?  Is there still one ?
An updated circuit diagram would be helpful because from the video it's quite difficult to get how the components are connected.
joellagace
Yes it still needs some sort of input to start, It don't seem to care how as long as it gets about 1.5 volts to start up, It can come and I have tested from the output of my first circuit diagram or similar, My apologies for not updating every little thing. as I keep experimenting and slight modifying, But yes at the core its still the same.  If I don't want to wait on accumulating charges then I can give it a kick start with a 1.5 volt "bust" from any source if I have it..
The First circuit accumulates ambient and gives out low voltage pulses, These pulses get sent to another circuit, That charges up another capacitor array,  When there is enough of a charge, About 1.5 volts or so it triggers another circuit. This one I didn't make a schematic,  It's just the most simple one transistor "flyback" or what most would better assassinate the name to that of a "joule thief" that I use to Drive spark high frequency to my coil.
Now on the Kapa coil, Yes 2 separate grounds, I still use cold water ground and Radio antenna ground. Hocked up Ground wise just like all the Kapa schematics. ....
Now where i'm supposed to have the inductive load , I replaced with a network of high frequency transformers I had laying around from anther "fly back" project I worked on in the fast.  Each transformer primaries in parallel. They all have their own rectifier circuit, feeding rectified output input, flyback (spark drive circuit)
Its messy and I'm still working/experimenting/changing in real time on trying to represent it in schematic..
As you see in the video once it stops(usually caused by me!!) I can't always start it up right away again! I have to wait a few mins and tinker with it.  And it worked better last night for no apparent reason other then environment conditions so that's interesting as well.
joellagace
Here is the updated schematic, I'm sorry it took so long. I'm always experimenting and changing something. So far this has been the best configuration in self sustain mode, But This is just experimentation, The ultimate goal is still to drive a special high frequency AC motor and spin a generator.  But I must first experiment with everything I can first.
The Vacuum tube as a load seems to give me interesting results, Seems to work better as a cold cathode reaction. I tried warming up the heater with no apparent effects? I'm not sure why, As a Side effect, It spits out such strong blanket wide band HF all around the spectrum and the neighborhood. Not good thing but it was interesting for the sake of the experiment, As the  lightbulb inductive loads didn't do this unless I had my radio right "on" one of the coils to hear the typical "magnetic" noise.  Maybe perhaps a "better" radio circuit could be built around the primitive tube circuit and take  full advantage of this amplification effect. To power a strong radio HF transmitter with very little input drive. Who knows!
Anyways I have a youtube video to upload of my generator running well in this self sustainable test mode. Still wondering what to try out/change next?
Youtube video of it working here.
https://youtu.be/yh1mTUKZ71Y
