Cheop's Tesla Grid
Started by synchro1, January 18, 2020, 02:46:04 AM
synchro1
two solar orbital salvagings;
synchro1
This clinches it: Look at the resonance towers on the Yonaguni heiroglyphic.
synchro1
Zigzag Structure: 51°56'5.50″S 5°33'2.62″W. This is identical to the Zigzag structure located on the bottom of the Indian Ocean at the Mu point.
A "Sphere in a Cube" would yield an X Longitude a Y Latitude and a third Z axis. The Cube has 8 corners. The Mu points are at the Corners.
Yonaguni is at the conjunction of the Z axis and the Y Latitude 90 degrees from Cheop's. The hieroglyph shows two resonating receivers on the top of the Pyramid. A depiction of the "Solar Thermocouple" can be seen below the Pyramid on the carving too!
The Ice Age theories place the origin of these structures to remote Eons ago, predating the emergence of Homo sapiens as a Specie on the Planet.
synchro1
Mu point Southern Hemisphere. Connecting the 2 suboceanic zigzag patterns Atlantic and Indian Ocean would run a line directly through the center of the planet. they appear to be polar grounds.
I am declaring myself the discoverer of and naming them the "Synchro Grounds". How astonishing that these two identically sized grid patterns should appear at an exact 180 degree opposition directly through the center of the Planet! This amounts to a Profound Discovery of mine! I am declaring myself the Father of:
                                                          "Tesla Archeology"
synchro1
What would happen if we connected those Grid points to a Spark Gap by two giant undersea cables? We could broadcast power from a Tesla Transmitter to resonating receivers from the connection between these two points!
These artificial Grids are identically Isomorphic and antpodal geographically ( Diametric Corners). They are the relics of a Pre Humanity Global Power Grid.
Two cables of equal length would meet at the Great Pyramid in Cairo. An "Arc of the Covnent" would appear, with the power of the Planet!
