Motor-generator Vyrdudji System
Started by rakarskiy, January 22, 2020, 03:27:45 AM
Toolofcortex
Yes, your books are very nice, I am still reading.
I will use for reference for my Testbench.
Toolofcortex
Quote from: rakarskiy on January 22, 2020, 02:54:18 PM
The flywheel is a storage device, and for our purposes it can only work in a pulsed kinetic circuit. For example, the question: What is a charged electric capacitor? How to determine this? Second question: What is a charged flywheel? I have my own point of view on this issue, set out in my book.
If a flywheel is a mechanical capacitor, then what is a mechanical inductor?
citfta
Quote from: Toolofcortex on January 22, 2020, 05:38:36 PM
The flywheel is a mechanical inductor.  A balloon or pressure storage tank is a mechanical capacitor.  A spring could also be considered a mechanical capacitor.
rakarskiy
An inductor is a part of an electric machine that is responsible for creating a working magnetic flux in it. As an inductor, both the rotor and the stator can act.
The capacitor is designed to store charge and energy of the electric field..The capacitor is a passive electronic component. The capacitance of the capacitor is measured in farads.
A flywheel is a massive rotating wheel that is used as a storage device (inertial accumulator?) for kinetic energy or to create an inertial moment.
The principle of operation of the capacitor is as follows: when an external EMF source is applied to the capacitor plates, the dielectric located between these plates begins to accumulate energy in the form of an electric field.
The word accumulator is translated from Latin as (accumulo) - collect, accumulate. The algorithm of this product is as follows: It uses a reversible chemical process that takes place in the electrolyte and on the electrodes (cathode and anode).
That is, the principle of operation of the flywheel is suitable for comparison with the algorithm of the capacitor, not the battery. The battery stores energy in the form of a reversible chemical reaction. The flywheel receives kinetic energy, which it accumulates. The capacitor receives electrical energy and accumulates it.
You can also compare the flywheel and the condenser with the verb CONDENSE. An inductor is a Converter of electrical energy into a magnetic field.  What did you want to compare, which mechanical means converts mechanical energy into a magnetic field? Sounds like fun.
Toolofcortex
What about this nonsense here? Is it the international scam mafia again?
What is it with people and big costly investments that dont work? This thing must cost at least 50,000$
I mean yeah... The camera is filming and they are acting busy? Are they gonna call the prince of Saud and threaten him??? WTF is this cheap video accomplishing anyways?
https://www.youtube.com/watch?v=g_Z1S_1GlxA
What of the German flywheel engine that went into submarines in your book?
Form what I see, This and the Chas designs would have slower delay vs the indian 1 shaft design.
This obviously can only be and must have to do with impulse delay. The thing is, in this Turkish video I see nothing that ressembles an eccentric or loose flywheel
that could act as a disconnecting force and the sprocket seems totally circular. So the reaction time will be there, only slightly more delayed than a straight shaft. Or maybe its all in the output thyristors ?? Mess with the CEMF???
But also, there is a second part to this, this I take from the user "libra-spirit", If the electrons in the flywheel and protons go by centrifugal force, what happens when there is an oscillation of acceleration?
Does this "movement" cause some sort of motion in the "ether".. I mean, ever since the Schwartz thing all bets are off... What are "solar rays"???...
I see some turkish comment, video, about "axial flux generator"... Is this what the Turkish originator is telling his people?
https://www.youtube.com/watch?v=OopKS0DlQz8
And a good recap...
https://www.youtube.com/watch?v=hZ1sfTmDvnw
