Can someone help what does this waveform means or how to get it
Started by justawatt, January 24, 2020, 08:14:56 AM
justawatt
skywatcher
Quote from: justawatt on January 24, 2020, 08:14:56 AM
I got a mail from an russian group.they said if you can make
This waveform you can get free energy.
This means: if this waveform can not be made (which is true) then there is also no free energy (which is most likely also true).   8)
About your device: if you get 10 kW out with 200W input, you can close the loop, and get 9.8 kW out without any input.
If closing the loop doesn't work, you have nothing.
Toolofcortex
Thats his waveform when in the X/Y mode, the mode that nobody ever uses cause its useless.
Anyways I dont like this vidoe because he never moves the wooden plank and there could be a wire setup beneath and simply drilled.
Hole in cheap table + chea montage for a quick scam ? Ive seen earth engines made just to scam people...
You could mathematically derive in time from this waveform.
skywatcher
Quote from: Toolofcortex on January 24, 2020, 12:21:53 PM
Even in x/y mode it's hard (or even impossible) to get such a picture because if you have periodic signals the curves would always be closed, even if you have multiple phase delays. How does the trace get back from right to left, or from bottom to top ?
Of course it's to possible to write any curve form in x/y mode but not with analog circuits which generate periodic waveforms.
Toolofcortex
You should ask on DIYaudio or EEvblog, in the scope and audio section.
Dont mention free energy. Just ask a riddle.
No idea how he got that,
