less 20ns switching in a coil without transistors
Started by giuseppe, February 01, 2020, 03:40:09 PM
Toolofcortex
You will not get nS pulses.
The contact time will be larger than that.
It will be in the uS.
It's also less accurate and will degrade.
It was used back then when there was no alternative.
Raycathode
is all you appear to need to be able to do is charge an HV cap over a short time and then 'bang' dump and discharge that energy into a coil that's what they say and it works in TV sets so it's just that discharge time.
Toolofcortex
Ok I see what you mean...
Just charge the line let it flow at the peak points where air onizes and turns conductive.
Yeah that would work too.
It would not be a precise and accurate pulse all the time tho.
Raycathode
This thread looks Abandoned However this might be of interest.
Here is one way using Bucking coils the pulse width is some where around 520 nano-secs
it uses enhancement fet's and driven by a constant current around 3.5 volts max with the type of fets I have.
Other fets will behave differently 20N50's mounted on a heat sink which runs cold the bias is 56R shunted with
a 47pf on each gate coil, current is 1.307Amps at 3.25 volts.
There is a scope shot too, the LEDs are 1.25W consumed is 4.5W that isn't OU it's a loss'  ::)
Raymondo
