David La Point and over unity claim
Started by ramset, February 01, 2020, 10:20:30 PM
ramset
Jimboot s getting it done
(Handling those neos must be daunting!
Quote from Jim ( link above)
Ok 1st one complete. Getting the pms in is a bitch. It will fire other neos 3m across the room. So he is right about that.
------------------------Shared with gratitude and respect
Chet K
Thanks Grandma
Jimboot
Thank for posting Chet. David ticks all the boxes for me to attempt replication. Open source, trained working scientist and it came to him in a vision  8)  which is cool. I have a few skinned knuckles  ;D  re the entry/exit forces required and sticky points. Given that in his experiment shows 4 bowls with the pm passing through, he has demonstrated (for me anyway) that this is not suffering the same issues as other mag gates I've worked on. The length of the pm passing through the bowl is important. With all n facing out in the bowl a s facing pm is initially dragged in. The sticky point is at the base.
ramset
Jim
If we make a respectful venue here
We undoubtedly will be able to invite
David !
Thanks for doing this ,Will reach out for Stefan tomorrow (actually it's later today )
About a moderated builders board !
Tremendous Gratitude
Chet K
Thanks Grandma
Jimboot
Sounds good Chet.
With the bowls placed 60mm apart,  the gap between back and front is 15mm. As the 38mm stack of neos exits the first bowl, half of it has already entered the 2nd bowl. I'll be buying more neos to complete the 2nd bowl. I think this may work as described.
Floor
First video posted here...
https://www.youtube.com/watch?v=nWESbALZELQ&feature=youtu.be
Measuring the           total work that must be done          in order to push the stack of
magnets into a single one of the domed field units (up to the very point at which the stack
is drawn in) must be done in order to know if the input is less than the output. Peak force
is not an indication of the work done / energy expended.
                    Yes, that is, total work     in each direction    of entry.
If a linear / series array of the bowls is accelerating the stack of magnets,,,
1. Are the fields from the bowls combining ?
2. If the fields are combining, has this increased the work required to
initially, insert the magnet stack ?
The voltage is successively increasing as the stack progresses through each / the
next bowl.
1. Is this due to an increased speed of travel of the magnet stack ?
2. Is this due to a combining of the bowl fields ?
3. is it work from permanent  magnets ?
If the device were self looped the speed of the travel of the stacked magnets
might continue to increase until some balance against wind resistance is arrived at
or the device exceeds its own mechanical strength to retain the magnet stacks against
centrifugal forces.
Higher speed would produce greater energy and greater power.
Net gain, may or may, or may not be there.  The test method may be flawed.
Opinion...
The demonstrations and oscilloscope displays do not as yet / definitively, demonstrate
a net gain in work from the magnet interactions.
                due to no...
1. peer review
2. replication
3. additional kinds of tests.
Opinion...
1. peer review
2. replication
         are merited here
    P.S.
Thank you to David La Point
        for sharing your explorations !
