generator 15 kw
Started by boris1988, February 10, 2020, 03:17:40 PM
conradelektro
Quote from: boris1988 on February 14, 2020, 06:04:50 AM
i am intresting in rotoverter sistem but i don t now how it work and it is standard 3 ph motor
how to get from 3 wires 9wires
Nobody has ever proven that a rotoverter works as intended. Find something better to do.
Something to know about free energy:
Free energy is not banned and it is not forbidden. But nobody has ever shown "free energy" conclusively.
One can not prove that there is no "free energy", because to prove a negative is logically not possible. One would have to prove that free energy is feasible, but nobody could ever do that.
In other words: nobody has ever demonstrated in a credible and sustainable way that a machine or any contraption puts out free energy.
You may still have fun with "free energy", but you will not get more energy out than you put in. Self deception is a great way when looking for free energy. You can also try to deceive others, but few will fall for it and even less will pay you money.
You might want to save the world, but the world does not need saving by you. Save yourself if you can!
Greetings, Conrad
conradelektro
15 KW generator /0,9 ( for 90% efficiency) motor = nominal 17 KW motor power and 100 KW start phase power demand : inrush voltage and inrush current 6 times nominal value
The 100 KW by flywheel  ? Capacitor bank  ( ~ ultrabattery ) ?
But assuming maximal 90,% generator efficiency you will get 0,9 x 0,9 = motor-generator  0,81 C.O.P.
For a C.O.P. ≥ 1 you need to find the specific generator rpm-motor rpm step up or step down transformation ratio !
Try it for example with a 7 hp ( used,leased) ic-engine and +- 5.000/6.000 rpm
Prototyping with high power devices becomes fast expensive  !
boris1988
how to calculate the flywheel kw have
