Coronavirus,uesfull information for fighting Virus [evolving from effected areas
Started by ramset, March 08, 2020, 08:56:50 AM
citfta
AC/onepower
Population density means the number of people per square mile.  Canada has a population density of 3 people per square mile.  The U.S. has a population density of 84 people per square mile.  So the U.S. has a population density of almost 30 times the population density of Canada.   You sure like to make yourself look foolish.  And as I said before that makes it much more likely one of us will come in contact with someone else that has the virus.
Throwing in all the other stuff about wars and other things is known as trying to redirect the argument because you know you are losing.  None of that has anything to do with the spread of the Covid19 virus.
And I see you still haven't answered my question about what guidelines we haven't followed that according to you have made a difference in Canada versus the U.S.
Carroll
Quote from: citfta on May 07, 2020, 06:00:54 AM
AC/onepower
Carroll
Hello citfa,
#174 shows you other numbers ! By which statistics resource their numbers do you do your statement about "84/3" ratio,from when this numbers ?
Sincerely
OCWL
Quote from: Johan_1955 on May 07, 2020, 04:22:20 AM
https://www.youtube.com/watch?v=KSnvZB7MbgE
https://www.youtube.com/watch?v=RmWwRvb3-ow
https://www.youtube.com/watch?v=ASji-S5XyF8
Pasteur : ausgehen dasz dieser gemeint ist  https://de.wikipedia.org/wiki/Louis_Pasteur welcher lebte von/bis
                       * 27. Dezember 1822 bis 28. September 1895
1895 als Gedanken-Basis : wie hoch war zu dieser Zeit die Aufloesung/Vergroesserungsfaktor von Mikro-Skopen ?
                                        https://de.wikipedia.org/wiki/Mikroskop
                                       Welche Groesse erreichen Mikroben/Mikroorganismen,deren Keime,deren Plasmen ?
                                        https://de.wikipedia.org/wiki/Mikroorganismus
Plasma : sogenannte "reine Information",so wie sogenannte "Computer viren: neuronale Befehlsverkettung " wohl zu vergleichen aber auch wie die Informations-Einheiten welche von jedem von uns im Alltag abgegeben werden : ein "fuerchterliches" : Ja ! Es,das Haustier,musste beim Tierarzt eingeschlaefert werden ! Wie dieses den Kindern erklaeren ?
Ein "himmeljauchzendes" : Ja ! Sie will Ihn heiraten,worauf er nach mehreren Versuchen und mehrfachen Bitten endlich ein positive Antwort bekommen hat !
Aus dem obigem Louis Pasteur-wikipedia-Artikel : Im Auftrag der französischen Regierung erforschte Pasteur verschiedene Krankheiten der Seidenraupen und  erkannte sie als Infektionskrankheiten.
Da musz wohl die Art und Weise der "INFEKTION" aus der seinerzeitigen Louis Pasteur Ansicht eroertert werden,wenn nicht durch "Viren" !
https://de.wikipedia.org/wiki/Viren
2011 waren etwa 1,8 Millionen verschiedene rezente Arten bekannt, die als Wirt fungieren,[4] jedoch lediglich um die 3.000 Virenarten identifiziert worden.[5] Viren befallen Zellen von Eukaryoten (Pflanzen, Pilze, alle Tiere einschließlich des Menschen) und Prokaryoten (Bakterien und Archaeen). Viren, die Prokaryoten als Wirte nutzen, werden Bakteriophagen genannt; für Viren, die speziell Archaeen befallen, wird aber teilweise auch die Bezeichnung Archaeophagen verwendet.[6][7]
Die Wissenschaft, die sich mit Viren und Virusinfektionen beschäftigt, heißt Virologie.
Bekannt/identifiziert ratio bis 2011 ! 2011-Mai 2020 ?
Humaner Bioorganismus :
Genom ? Erbsubstanz ? Dr. med. Hirschhausen "humane Biomasse und die Mikroorganismus-Anteiligkeit " !?
Aus dem L.Pasteur Artikel ;
Verstorben 1895 :
Aus dem Viren-Artikel:
Dimitri Iwanowski wies unabhängig von Mayer im Jahr 1892 in einem Experiment nach, dass die Mosaikkrankheit bei Tabakpflanzendurch einen Stoff ausgelöst werden kann, der durch Filtration mittels bakteriendichter Filter ([Chamberland-Filter) nicht entfernt werden konnte und dessen Partikel deshalb deutlich kleiner als Bakterien sein mussten. Der erste Nachweis eines tierischen Virus gelang 1898 Friedrich Loeffler und Paul Frosch, die das Maul-und-Klauenseuche-Virus entdeckten (siehe auch virologische Diagnostik). Die Größe vieler Viren wurde in den 1930er Jahren durch William Joseph Elfordmit Methoden der Ultrafiltration bestimmt.
Zero positive/Zero negative : aus psychologischer Sichtweise positiv=gluecklich oder negativ=traurig ?
Vom Mittelwert positiv=mehr und negativ =weniger als Durchnitt,zyklisch-chronisch ?
https://de.wikipedia.org/wiki/Krankheit
https://de.wikipedia.org/wiki/Pathologie
                           Frueher war dieses wohl diese Begriffe darstellend (aktiv,passiv),
      Deologie/Theologie und  https://de.wikipedia.org/wiki/Deontologische_Ethik       https://de.wikipedia.org/wiki/Teleologie  https://de.wikipedia.org/wiki/Teleologische_Ethik  ;
        Askese :
     Ultra-Jainismus zu extrem Brahmanismus zu max-min ( Dawn-Yates law in der Wirtschaft) Bhuddism zu einfacher alltaeglicher Lebensweise,besonnen und bewusst
Vater = Wesen/Gestalt/Form /Gott/Geist                                   Sohn= Logos entspricht Kundigkeit/Lehre              Heilige Geist = Anwendung/Erscheinung
                           https://www.simplypsychology.org/perception-theories.html
