Simple and powerful principle
Started by nix85, March 17, 2020, 07:30:59 PM
FreeEnergy
The amount of fluid loss from the upper tank is very little.
A heavy float should be able to produce enough energy as a falling weight to pump water back up.
seychelles
THEY MIGHT BE POOR BUT NOT STUPID. THERE MUST BE SOME TRUTH
IN THESE MACHINES.
https://www.youtube.com/watch?v=VWgAPB5nReU
ramset
Seychelles
A good salesman can sell plenty, most FE scam guys
Are good salesmen ....unfinished unshipped machines ?
Two guys working around dozens unfinished?
Camera guy should have started movie at machine running
Equipment that the two workers are using!( yes I know could easily be faked too)
FE scammers ( some very longtime guys)
Some names I don't want to write here come to mind ....
Makes the blood boil too....
However there are some guys that will say this design you
Post
"Can" be done ... but don't say how or show working units
So not open source??
This one however should have many more workers IMO
Your link again https://m.youtube.com/watch?v=VWgAPB5nReU
Respectfully
Chet K
Ps
I believe the buoyancy concept being mentioned here has been tried ?
Not sure where link is
Forum could use much more organization ...
And of course you never know what new twist could make things cycle
( utilizing magnet or heat or other influences to tip scale
Thanks Grandma
Floor
Quote from: FreeEnergy on January 28, 2021, 05:40:30 PM
The design presented by nix85
@    https://www.youtube.com/watch?v=rxFXsoqbfrk
is I think a very cool design.  If one has a large reservoir at height,
(for example, a mountain lake) one could use the system indefinitely,
as long as nature refreshes the lake with rain at least as rapidly as
the device uses it.  In that case it would be a "free energy device",
in the same respect, as is a dam and power generation station upon a river.
The device would be a free energy device, because the sun and wind are free.
    other wise
One will expend exactly (at best) the same amount of energy in lifting water to
fill the upper tank (pumping water) as one would expend in lifting the float by
some other method.
Before friction losses and so, the system is exactly unity.  After friction losses
and so on, the device is less than unity.
     There is no net gain in energy.
The heavier the float used is, the more VOLUME it needs to have in order that it
will be less heavy,  than an equal volume of water.
If the float is not less heavy than an equal volume of water, then it will not float.
The float, in falling from the upper tank, would only ever be able to lift exactly the float's
own weight in water (at best), and then only if the system has not losses as friction
and so on.
floor
