All Permanent Magnet Motor
Started by magnetman12003, March 28, 2020, 03:43:49 PM
synchro1
@magnetman12003,
Your new design amounts to nothing more then just adding weights to egotronics model: No different from attaching nuts and bolts to the magnets with the nuts screwed down.
ayeaye
Quote from: skywatcher on May 17, 2020, 05:41:49 AM
There is nothing to replicate because replicating would require a working device in the first place.
Yes right. Maybe Magnetman has done some experiments, that people can replicate.
One thing, in such setup it should move more in one direction, than the other. If there is any difference, and otherwise its well made, like well leveled, then this indicates overunity. Has Magnetman done any such experiments?
But then in the more measurable way i think, the force when moving in one direction, should also be greater than the force when moving in other direction.
synchro1
Magnetic nuts and bolts attraction would dampen any oscillation on egotronics magnet fan. I see space for a hamster inside at this point.
conradelektro
I am still hoping that Tom (magnetman12003) is on to something interesting, therefore I have some questions, see also the attached drawing.
Am I right that the distance of the wooden disk from the (blue and red) disk magnet is kept by the "two full ceramic wheels stacked on the center rod"?
The ring magnet wants to push the wooden disk with the 45° magnets upwards, but the weight of the wooden disk and the 45° magnets push downwards? The "full ceramic wheels" carry the remaining weight of the wooden disk (with the 45° magnets and the tumblers with the rods)? Therefore there is a fixed distance between the wooden disk and the ring magnet?
Greetings, Conrad
magnetman12003
Quote from: conradelektro on May 17, 2020, 11:10:09 AM
Greetings, Conrad
A Gibraltar TALL ( There is short ones)  flanged base cymbal sleeve 8mm is what pivots the 1/4 inch thick wood base I have
The mounted wood setup is under of a old 45 black record.  Cymbal  sleeve Found on EBay.
The 50x 25x 10mm  (4 each) cuboid magnets are set at 45 degree angles by
45 degree brackets silver furniture angle joint corner support. Both Found on EBay.
I am going to enclose a photo of the two all ceramic wheels separating the wood setup disk from the
Large ceramic ring magnet under it.
Tom
