Alternative Partnered Output Coils and Free Energy
Started by Raycathode, April 03, 2020, 12:14:05 PM
Sr.Rocha,peco por desculpe-me por os erros escritos ! Tinha escrito com um tablett !
Talvez,sem pesquisa,so um pouco pensamento,talvez da visao ( para frente):
dum senhor inventor muito conhecido ,ao fim duma empresa chamada Bell :
https://worldwide.espacenet.com/publicationDetails/mosaics?CC=US&NR=181553A&KC=A&FT=D&ND=3&date=18760829&DB=EPODOC&locale=en_EP
para o conceito dum espanhol Ramos Suarez :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=6&ND=3&adjacent=true&locale=en_EP&FT=D&date=20070201&CC=ES&NR=2265253A1&KC=A1
qual ja da visao de geradores com 5 KVA e mais ,chega para casas privadas ( tambem para bicicletas electricas e pequenos carros ) !
Um pouco mais motivacao,por favor,voce fala de ter familia, e os membros em conjunto tem de resolver este momento difficil
(filhos veem muitas vezes mais que os pais pensam ! Coisas/situacoes boas e coisas/situacoes mal )!
Talvez um telephonema/mail para a Espanha ?
So posso ,nesta momento, tentar a ajudar ,um pouco,
Uma boa noite
OCWL
ramset
Nelson
Yes I understand,the door must always be open here
For you ..(offer of resources and equipment from open source community )
Thanks for all you do , IMO your example here does shine.
And hopefully will grow and bring change to help many in these
Difficult times.
Respectfully
Chet K
Thanks Grandma
ramset
Pssssst Lanca.. I would refrain from posting at main Partner coil topic unless you decide to build and share there.
Stefan is updating forum and has offered to clean up topic and hopefully make a path towards teaching .
for clarity Original poster Chris wants to teach...and discuss builds/experiments.
Thanks Grandma
nelsonrochaa
Quote from: lancaIV on April 16, 2020, 07:21:10 PM
Uma boa noite
OCWL
I appreciate, your support Lanca , thanks .
Best rewards
Nelson Rocha
#8850: EMJunkie,a good morning,
*reliant* does this topic to EE geometry,there Trigonometry,not plan/flat but STEREOMETRY related !
Sinus,Cosinus,Tangens to Phasor and Phase angle his shifting lagging/leading : displacement !
Triangulation as part from Trigonometry,active displacement by us user ! Are you user ?
EE-Schemes are translations : Geometry to Algebra and back
Please,do not give *JUNK* respond and show us adultness and wisdom from your inner side and experience !
before answering : when you take online-tutorials you read about instantenious power and average power,Professor Kanarev used other expression for the first :amplified
W(one Joule per second),VA and VAr :high amplitudes normal but not indicating *C.O.P.*
Because Joule is  based by heat-units,the ancient Physics unit calori ( calor = heat ) real power EE can be measured by specific choiced liquid/grained/solid material his mass heating and then before/after measurement and comparison !
So instead imagination/,could be that .....-speculation we get by this method trust-  test repeatable numbers,clearly analysts concentrated working  !
Because:     apparent power ,written S,in SQUARED              =(equals) real power ,written P,in SQUARED plus reactive power,written Q,in SQUARED
finally we get by mathematical  displacement for PSQUARED = .......then PSQUARED side by rooth math
P=root [ (S and Q)SQUARED]                root  PARENTHESIS in SQUARE BRACKET         root in german Wurzel    verrottet = Wurzel kaputt ::)
over these following steps we get reactive power Q and apparent power S values ,by STEREOMETRIC MODELLING !
                                 WE ALL HERE IN THE DIGITAL ONLINE-FORUM :  BE(-ING) DIGITAL https://en.wikipedia.org/wiki/Nicholas_Negroponte
                                for                          https://en.wikipedia.org/wiki/Computer-aided_design
                                for                          https://en.wikipedia.org/wiki/Numerical_control
                                for                           TRANSFORMATION
                                                              Forum equals " small cybernetical cloud "
                                 But KYBERNETIK IS MUCH :
                                 THE SCIENCE ABOUT ENERGY AND MATERIA/MATTER AND HER REVERSIBLE TRANSFORMATION
https://www.google.com/search?q=kybernetik&rlz=1C1AVFC_enPT797PT797&oq=kybernetik&aqs=chrome..69i57.4593j0j7&sourceid=chrome&ie=UTF-8
More than 2 decades before I got some publications from this inventor,scientist from Romania to read ( and to think about), only Florian R. Popescu meaning in this listening :
( was reference from Net-Journal page which Felix Wuerth ( R.I.P.) ,inventor, in the Beginning 90´ last century sended me,mainly his work investment offer related),
Uni-Docent in RO Florian Raul Popescu-Goetsch ( probably in contact with Matei Marinescu,great RO academy scentists,I personally assume )
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=florian+popescu&CPC=&IC=&Submit=Search
" theme" content in publications ,also https://de.wikipedia.org/wiki/Albert_Ducrocq
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fde.wikipedia.org%2Fwiki%2FAlbert_Ducrocq
https://www.heise.de/tp/autoren/?autor=Erich%20Bieramperl   Erich Bieramperl about DIGITAL SOCIETY and DIGITAL (E-/)VOLUTION
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=erich+bieramperl&IN=&CPC=&IC=&Submit=Search
https://books.google.pt/books?id=KAApCwAAQBAJ&pg=PT487&lpg=PT487&dq=bieramperl&source=bl&ots=XhH9lQodQZ&sig=ACfU3U3WFhdyaWkA6Duz1MHdfbllrHALqQ&hl=de&sa=X&ved=2ahUKEwjC3Kvbp-_oAhVB8BQKHUxlB94Q6AEwEXoECAsQKw#v=onepage&q=bieramperl&f=false
(  Easy,is it not ? AC curent and AC voltage maths ! But experiened scientistical re-/searcher work by this way ,so your team and the participating experts will have dossiers with such experiments reports,do they (not)?
And do correspondence and comparisons,do  they (not)? )
trustable ,repeatable,school/Uni-/Academy of Science demonstration -able results = *peer review * and grant-able !
I asked you during this week about measurement data,dossier/report data,you did not showed this data:
to all of us here in the forum and its viewers non-membered !
This answer shows clearly also *aboveunity*-teamwork status quo :
physical and by stereometrical application and  repeat-/approveable
                           real success or erroneous fail ,what ever can happen !
IMPEDANCE TRIANGULATION and POWER TRIANGULATION with POWER FACTOR calculation
You write about *C.O.P. 1,89*  : which  input and by which output measured data,
more nobody should expect from *aboveunity*-representants to get explained
the process mathematical for later device macro-and/or micro-nization !
    q.e.d. in physical EE-conventional units !
Sincerely by my best regardsOCWL
p.s.: we are here in an online-forum: nobody is here *SAYING*something,we all are writing and doing description
     in words,digits/chiffres,by image/movie/-s or giving links (open or by PM) and ever by standpoint from
                        *Nettiquette*/forum rules application and/or who can : common gentlemans agreement
        by no hurry
*We will change the World!* I heared two times EE-World (and in-/directly my participation related) in national language/linguagem :
        NOS vamos mudar o Mundo !
2007 Lisbon/Loures and 2013 Gondomar/Justice Palace(I as testemunho/witness)
To change our World is more need than only words and the will to do this : no resist and good partnership
AND NOT FINANCIAL PROJECT RESULT DEPENDENCE
Archimedes,Mr.*HEUREKA* ,in german meaning  :die Welt von den Angeln=*ihren Fesseln* hebe*l*n
                                       PHASE SHIFT
https://de.wikipedia.org/wiki/The_X_Factor_(Vereinigtes_K%C3%B6nigreich)  only ? A-Z-Factor ?
https://www.youtube.com/watch?v=oSfYryXmTj8 to and for MENCHILDs
Kinder an die Macht
Herbert Grönemeyer
Die Armeen aus Gummibärchen
Die Panzer aus Marzipan
Kriege werden aufgegessen
Einfacher Plan
Kindlich genial
Es gibt kein Gut
Es gibt kein Böse
Es gibt kein Schwarz
Es gibt kein Weiß
Es gibt Zahnlücken
Statt zu unterdrücken
Gibt's Erdbeereis auf Lebenszeit
Immer für'ne Überraschung gut
Gebt den Kindern das Kommando
Sie berechnen nicht
Was sie tun
Die Welt gehört in Kinderhände
Dem Trübsinn ein Ende
Wir werden in Grund und Boden gelacht
Kinder an die Macht.
Sie sind die wahren Anarchisten
Lieben das Chaos räumen ab
Kennen keine Rechte
Keine...
Quelle: Musixmatch
Small CHANGE,cooperative ,COMMAND-consult  :
        zero CHANGE DECISION vote power / 0,5 vote power  / 1 vote full vote power : rights/obrigations
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.echo-online.de%2Flokales%2Fkreis-gross-gerau%2Fnauheim%2Fkinder-haben-das-kommando_20468515
Anymore ? Cause kids-(childs-/)government ?
https://image.kurier.at/images/cfs_616w/3436216/46-145534435.jpg
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fchrismon.evangelisch.de%2Fartikel%2F2019%2F46680%2Fzehn-filme-die-schuelern-und-konfirmanden-helfen-antisemitismus-und-nationalsozialismus-zu-verstehen
Klug-Guck-Clan membership ?  ::) :)
http://www.art-michelangelo.de/images/erschaffung-adams-detail-480.jpg
New touch ?
With hi-story ?
Old,cause this worthless ?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=39&ND=3&adjacent=true&locale=en_EP&FT=D&date=19811001&CC=DE&NR=3006520A1&KC=A1
THINK DIFFERENT
