New Russian Selfrunning Permanent Magnet Motor
Started by hartiberlin, April 04, 2020, 05:41:57 PM
citfta
I have watched several of his videos.  In a couple of them he appears to hold the magnet in his hand close to the magnet on the rotor to see if it is attracted.  Then he sticks it to the rotor away from the magnet already on the rotor and then slides it closer to the magnet already on the rotor.  I think therefore he must have the same polarity pointing out from the rotor.  I have also seen a video where the magnets in his hand have jumped to the magnets on the rotor instead of jumping to the rotor.  Of course I am only guessing from what I have seen and could easily be wrong.
Carroll
Floor
First video
When the magnet is held by hand it is very easy to not realize that the rotation continues due to input from the hand's slight motion / input energy. Notice that he achieves
a much greater speed or rotation in the video where in, the magnet is hand held.
The rotation when the magnet / s are fixed should / must constantly accelerate
or else the device is probably driven by some hidden means.
This is because, each prior rotation gives enough force to cause increased speed / increased momentum and the subsequent rotations will add to that momentum and speed. There fore
the device must continuously accelerate.
Friction in the bearings will not prevent this continuous speeding up.  Because that friction will be constant / not increasing. Wind resistance would eventually have increased to the point of a kind of
terminal velocity.  But this probably wouldn't occur until a much higher speed of rotation is reached.
  IMO
It might also be possible that inductive resistance might eventually give a kind of
terminal velocity.  But I don't see that as happening under the conditions in the videos.
In the other design (magnets over steel plates) the same things may apply ?  But it
seems to have very weak net force interactions and perhaps even a small increase in
wind resistance will cause terminal velocity  ?
Floor
The second device (magnets over steel plate) I find interesting.  Maybe it works (if it works) primarily due to the gradual magnetization of the steel plates?.  It is vaguely reminiscent of
the la Fonte pseudo solid engine's functioning ?
Note however, that in the pseudo solid engine, the moving component IS the steel plates equivalent.
In the La Fonte design, the moving component is polar reversed in its orientation in each next cycle.
This prevents its eventual magnetization.
synchro1
        "Abandon All Hope!"
This same guy perpetrated the "SMOT" hoax!
DaKrampus
well that confirms the 4th law of thermodynamics (or was it the fifth?): When something looks to good to be true it nearly always is.
