Partnered Output Coils - Builders Group - Moderated!
Started by EMJunkie, April 23, 2020, 06:52:38 PM
kolbacict
And what, in this device, someone has achieved any success?
I tried this, it didn't work for me.
alan
it must have the effect of a battery after the duty cycle. During duty cycle the input coil must create a potential on both output coils, after duty cycle mutual Lenz will try to sustain the collapsing flux by inducing current through the coils which sustains mutual Lenz induction, so the flux decays slowly, I wonder if the decay can be slowed down by using liquid nitrogen so it becomes a super conductor comparable to quantum levitation.
AlienGrey
Quote from: AlienGrey on August 04, 2021, 04:18:50 PM
It's not just partnered coils it's quarter wave, only hit the right frequency!
SIL
I used an old discarded 2" by 2" Elac recvovered core and wound it with the 30ft & 30 ft L1 and L2 at oposite
ends with a 1/4 wave primary using 4 strands of 7.5 ft of same primory wire.
Note tuning is critical around 211 khz on this set up
driving it with a SG thus colecting each 1/4 wave peaks it gives a nice sine wave peek at the output that
disapears under any load  ;D ;D
It makes a good junk box filler ! Sil
EMJunkie
This thread was supposed to be locked also, seems the agreement was broken again?
For those that are interested, your Partnered Output Coils need to do this:
https://www.youtube.com/watch?v=5BeFoz3Ypo4
The Magnetic Field Pumps Electrons from the Source, the Atom, accelerating them down the wire. Like this:
https://www.youtube.com/watch?v=Vo2-Qb3fUYs
Partnered Output Coils are the exact same analogy as an Electric Generator, the difference is we have no motion, we are Solid State, di/dt is the catalyst!
Output Voltage is "Generated", Antenna Theory is the best way to think about your Terminals:
See below Image, Where L is the Voltage Amplitude on your Output Terminals in Time t.
AlienGray is correct:
SIL
Input must be 1/4 Wave, Output must be 1/2 Wave, where V is at Maximum at Resonance! Some are smart enough to make this work, some just dont want to! Yes, one can use Harmonics...
https://www.aboveunity.com is back up and running after many hundreds of hours solving problems and much money spent:
https://www.youtube.com/watch?v=_G9SJ8vLNk8
Best Wishes,
   Chris Sykes
AlteredUnity
Quote from: alan on August 05, 2021, 08:47:14 AM
Yea, I barely got the hang of this, but my next step was going to blow it up in a hologram(real time), and find the matching pattern to the on the film of the hologram, find what would alter the interconnectedness of the projected image in the film, and construct a way to replace items in actual space time or pull energy from everything interconnected....I just havent had time yet....lol jk, but would freezing it change the frequency,  is there an effect on capacitors at that temp?
