Nelson Rocha Workbench
Started by hartiberlin, April 30, 2020, 02:57:05 PM
Raycathode
Hi Nelson, the subject you talk about above is in deed an interesting subject, however i fear Nick by self-admittance
might not be into experimentation unfortunately.
I have read the paper through but at the end, who ever wrote it admitted it wasn't the best route or best way to build such a device
he or she does talk about a second part to the document, I don't suppose you have access to that and that you might also share that too as That too would be equally appreciated.
Raymondo
nelsonrochaa
Quote from: Raycathode on May 30, 2020, 03:36:49 PM
Raymondo
Hi Raymondo ,
Unfortunately, that document was given to me by someone I stopped contacting a long time ago.
But I thought it might be interesting since it is linked to the theory of building the kapanaze device, and debunking about some points on the subject, where several tests are included in different configurations and in the construction of the coil.
And yes I know that in the document it is clearly stated that no excess energy is found, but I am sure that some points will be of great use to the most attentive and experienced exprimenters who continue to pursue that goal.
Best rewards
Nelson Rocha
EMJunkie
Nelson, basic question for you:
In Your Opinion; Does the Energy come from inside the Insulated Copper Wire? But only when the right conditions are met for the Charge to flow?
FYI: In reference to this post: Here
I am sure it does, at lower than the Electron Level, Energy may enter the Wire at that level, but the Energy we use, the Energy we measure, it comes directly from Inside the Insulated Wire.
I mean you had an Air Core!
Best wishes, stay safe and well,
   Chris Sykes
nelsonrochaa
Quote from: EMJunkie on May 31, 2020, 06:00:30 PM
   Chris Sykes
Hi Chris, hope you goes well,
Chris , in my opinion  the energy cannot be contained in the wire, inside or outside ; the material of wire it should be liable to be a path to charges (electron flow and for these movements occur, like cooper meets these conditions.
Therefore, it would not be correct in my perspective to establish that the wire contains energy, but rather behaves as a medium for energy manifest itself, in this case  when EMF is applied in the wire or by variation of magnetic field  by a magnet for example .
The electron charges in wire  acquired energy from outside to react and flow, but without this external energy should a current flow in the wire ? No .
This is my perspective .
Best Rewards
Nelson Rocha
NickZ
  And all energy in all generators come from that external source. Not by the movement of magnets by coils, like is still taught in schools. Without the external force we would still be lighting candles.
