Cyril Smith AKA Smudge builders group
Started by hartiberlin, May 20, 2020, 01:01:25 PM
bistander
Quote from: EMJunkie on June 06, 2020, 04:30:06 PM
Hey Bistander,
In a Symmetrical System, Conventional Transformer for example, the Energy Transfer Mechanism is Symmetrical, this means: 1 + -1 = 0, which is Input = Output - Losses = Below Unity
Best wishes, stay safe and well,
   Chris Sykes
Hi EMJunkie,
Efficiency = (output power) / (input power) * 100%.
Example:
Input power = 100 watts, output power = 95 watts.
Efficiency = 95W / 100W * 100% = 95% .
100W went in and 95W came out as useable power. 5W was lost, wasted, converted to heat or however you want to characterize it, but those 5 watts come from the input power and do not end up in the intended output power. 5W are the losses.
So 100W - 5W = 95W. Input power - losses = output power.
Rewrite the equation like this:
100W = 95W + 5W. Input power = output power + losses.
Straight forward.
Attached screenshot from:
https://pressbooks.bccampus.ca/singlephasetransformers/chapter/transformer-efficiency/
Regards,
bi
EMJunkie
Quote from: bistander on June 06, 2020, 09:41:59 PM
Hi EMJunkie,
Example:
Straight forward.
Regards,
bi
Hey Bistander,
Your example is the same, confirming what I said, just with a different equation: Input = Output - Losses = Below Unity is the same as 95W / 100W * 100% = 95% = Below Unity, same thing!
   1: Input power = 100 watts.
   2: Output power = 95 watts.
   3: Losses = 5 watts
100 = (95 + 5) but in Energy Exchanges, the Energy must always be the same, so: 100 = 100 - 5 = 95 Watts, or 95% or Below Unity. You see? You get this way of thinking about it? All Systems have Losses! So again the Input = Output - Losses!
If you run a series of experiments and benchmark a Conventional Transformer, what I said will make more sense.
   Chris Sykes
bistander
Quote from: EMJunkie on June 06, 2020, 09:49:51 PM
Hey Bistander,
   3: Losses = 5 watts
   Chris Sykes
Hi EMJunkie,
You say:
"Input = Output - Losses"
Using numbers from my example it is:
"100 = 95 - 5"
Using conventional math:
95 - 5 = 90
What am I missing?
Regards,
bi
EMJunkie
Quote from: bistander on June 06, 2020, 10:14:16 PM
Hi EMJunkie,
You say:
"100 = 95 - 5"
95 - 5 = 90
What am I missing?
Regards,
bi
Hi Bistander,
No, youre not following the Math.
   1: Input = Output = This says, the Energy Exchange is from the Input to the Output, Output is equal to 100 watts. This an example of an Ideal System, with no losses.
   2: Input = Output - Losses, this says: 100 = 100 - 5, or Input = Output - Losses.
All you need to do is follow the Maths. its self explanatory.
   Chris Sykes
bistander
Quote from: EMJunkie on June 06, 2020, 10:19:06 PM
Hi Bistander,
   Chris Sykes
Hi EMJunkie,
OK, have it your way. But there are thousands of textbooks and tutorial websites that agree with what I show. Nobody else that I've ever seen, met or heard about does it your way.
Regards,
bi
