"Magnet shear to direct pull work ratio"
Started by Floor, July 16, 2020, 08:59:39 AM
Floor
continuing...
                    The shearing work measurements...
27.
28.
29.  20 g      --- 95.5 deg      25 x 2            = 50
30.  10 g      --- 100 deg       15 x 4.5         = 67.5
31.    5 g      --- 107 deg       7.5 x 7           = 52.5
                                                          total = 11293
Had we stopped our measurements at 95 degrees in both of the measurement sets
instead of continuing on to 107 degrees in the one set...
the ratio would have been 11173 (sliding) to 9998 (direct pull)
                               because 11293 - 120 =  11173
at 100 degrees  there are 67.5 units of work  +  the 52.5 units of work at 107 degrees
                        (67.5 +52.5 = 120)
                                    and
                        11173 - 9998 = 1175 (still greater than zero).
                   See ?
                        We are not done yet !
                              floor
Floor
Force times displacement equals energy (in the form of mechanical work).
A mass of 102 grams, exerts approximately 1 newton of force (down) in earth's standard gravity
(as weight).
If we lift that 102 gram mass 1 meter, we do approximately 1 joule of work upon it, as that lifting.
Force times displacement equals work. 1 newton times 1 meter equals 1 joule of work.
But the force present in magnet interactions changes at differing distances.
So then, how does one calculate the energy present in magnet interactions ?
Floor
So..
The travel of a magnet (A) due to magnetic forces can be of a shorter
length than some other magnet's (magnet B's) travel due to magnetic
force and yet ...
if the average force along the travel of magnet (A) is greater
than the average force along the travel of magnet (B),  there can
be more energy present in the action of that magnet (A) than is
present in the action of magnet(B).
There is more potential to do mechanical work in the sliding magnet action
(presented / measured) than is present in the direct (face to face) action.
Next, we see if it can be looped as a net gain in work from magnets ?
Floor
Here it is...
the other two measurement sets...
less than 5 grams force, over the course of the one travel
               and
negative five grams force, over the course of the other travel.
   done...
     back to the other magnet device...
     @ https://overunity.com/16987/td-replications/msg556715/#msg556715
Floor
Disappointment again here, no spiny thingy !
Just cyclical work from magnets with a net energy gain ?
       later ...
         Always remember that ..
           While time might fly like an arrow,
              fruit flies like a banana.
