Magnetic Air Coil Generator MAG
Started by BorisKrabow, July 26, 2020, 01:55:16 PM
BorisKrabow
Hello ,
It's time to tell more about the design of MAG 1. ( picture at the beginning of the topic   MAG1_2.jpg  )
           The design of MAG 1 contains many effects that allow you to achieve free energy.
    The modulator is located in the Zero Line of the Magnetic Poles ( ZLM ),
located there to avoid the influence of magnetic fields .
   To simplify the description, it will be like this: Lenz 1 meets Lenz 2, but since they have the same magnetic pole, they are repelled from the Zero Line. This makes the magnetic field even stronger move through the air coils and generate more electrical energy in them.
      This phenomenon will occur with a particular modulator design. When applying a certain waveform. Also, the level of the magnetic field of the modulator must be within a certain range, otherwise the magnetic fields of permanent magnets will burst into the modulator coil and the overunity effect will be reduced.
                                                     To be continued
Best regards,
Boris
seychelles
BorisKrabow
Hello !
I added a picture showing the placement of magnetic fields in the air.
        This clearly shows why the MAG device looks like this . https://overunity.com/18563/magnetic-air-coil-generator-mag/msg548448/#msg548448
                There is a small gap in the middle of the magnetic fields where there is no magnetic field. By acting on it, there is a possibility of obtaining free energy.
                              I have an idea to place a Bifilar flat air coil in it.
nix85
this is along the lines of kunel and Silverhealtheu
https://overunity.com/18272/kunel-device/
it seems fast rise impulses are key here
BorisKrabow
Hi !
                 This is a solid state version of Mike Corbin's device.
  https://www.motofluxpower.com/     website
  https://overunity.com/19405/magnetic-flux-motor-just-patented-that-creates-its-own-electricity/      discussion on this forum
Ferromagnetic parts are shaded in the figure. There can be air gaps between parts to adjust efficiency .Numbers indicate primary and secondary coils.  Between the magnets is a modulator. Its design can have many options.
                    The purpose of the modulator is to regulate the interaction between the magnets with minimal energy consumption and thereby cause large fluctuations in the magnetic field at the location of the secondary coils.
                   Apparently, the large energy multiplier, stated by Mike Corbin, is due to the ratio of the size of the magnets to the device that changes the strength of the interaction between the magnets.
                                                 Boris
