Free Energy RANT CAFFE ASYLUM
Started by v8karlo, October 02, 2020, 03:11:51 PM
seychelles
THE SUN BURNS A BILLION TONS OF HYDROGEN GAS EVERY 5 SECOND TURNING IT INTO HELIUM .QUESTION IS WHERE DOES IT GET ALL THOSE BILLION TONS OF HYDROGEN? ANSWER ALL THE STARS IN OUR MILKY WAY GALAXY IS GETTING ITS FUEL FROM THE BLACK HOLES IN OUR GALAXY. WE DO NOT SEE THE TRAIL OF ALL THAT STUFF BECAUSE IT IS TRAVELING AT TWICE THE SPEED OF LIGHT. THE SUN EMITS ALL THE ELECTROMAGNETIC SPECTRUM THROUGH SPACE. EVEN HEAT IS TRANS VERSING SPACE INTO THE FORM OF INFRA RED LIGHT.
kolbacict
Quote from: seychelles on November 04, 2022, 01:37:54 PM
You got it all mixed up.
The sun, on the contrary, loses mass by about 4 million tons per second, due to radiation.
According to the famous Einstein equation. :)
ramset
Well
https://overunity.com/19273/unlocking-zero-point-energy/
Shared by member feb2006 ( also a very bright fellow)
A very bright fellow who has very deep credentials
Says constant 1.7 giga amp flow potential per square meter (available through photon manipulation?
https://m.youtube.com/watch?v=2tGRhTXKh8A
http://www.rexresearch.com/moddelzpe/Moddelzpe.html
Sounds good ....
Thanks Grandma
ramset
Hmm
I see last post timed out !
experimenters and builders should read this !
I hope it was properly routed here !
A theory made real... with a gain mechanism of 4 times input publicly demonstrated??
By a respected scientist!
Translated to English
Shared by F6FLT last year ....in a spot not easily found ( I did find and share here)
Edit: I see it seems to not open
It's not that big ... I'll do some screenshots
Edit again: just copy pasted and put images in screen shots below
Going to see if I can get more info on This !
"Synergetics"
So all this disagreement over Aether Ether etc etc
Sun ... not to sun ?
Moon power ....
"Snickers power"( not so private joke)
We need not battle over semantics
Just find it use it and teach how !!
ASAP
That's the plan here !
When we get there ...
Translated from French to English - www.onlinedoctranslator.com
  WHO WILL DARE
REFUTE
SYNERGETICS?
While the first synergetic generator has just worked, official science continues to ignore the work of Pr. Vallée. This is all the more serious as the work leads to energy independence. We therefore ask researchers to pronounce themselves unequivocally on the value of the synergetic theory.
Since a theory only has value if it is confirmed by experience, synergetics was tested this summer in Belgium. The results are positive. For the first time, a
power amplifier has operated with the sole external source of energy coming from the universe that surrounds us and belongs to everyone. The generator built at Morstel by Eric d'Hoker returned four times the power given to it, which in itself constitutes a disconcerting result, and quite inexplicable within the framework of ancient theories of physics. Because nothing is lost, nothing is created, and the additional energy found at the exit had to come from somewhere.
However, this additional energy apparently coming from nowhere undeniably confirms the synergistic theory of Pr. Vallée, whose basic hypothesis is the following: the interatomic, interstellar and intergalactic spaces of the universe, usually considered as empty, are in reality
the seat of an
electromagnetic activity in-
tense, and non-material, with continuous distribution, and which results from the superposition of distinct elementary waves propagating in all directions at speeds generally not very different from each other. We can translate this hypothesis in a more convenient form by saying that the structure of space is energetic. Matter can therefore exchange energy with space, and this has just been confirmed by Mortsel's experiment. What's more, this energy is limitless, and the device that captures it is relatively simple.
For our readers, this information is not new. It is now a year and a half since we gave a brief outline of the synergetic theory (February 1974 issue). More recently, at the beginning of this year (January 1975 issue) we took up the subject of the failures of nuclear fusion controlled by the Tokamak system, failures predicted and explained by synergetics.
Before coming back to this and to the Belgian experience of this summer, we must look into a rather curious problem: the absolute silence with which this new theory was received. Certainly, it disturbs many acquired knowledge and shocks many dogmas; but that no one among the specialists in fundamental physics has dared to give an opinion – for or against – is puzzling. Because the articles in which we questioned not only the CEA, but also some famous names in French science, did not elicit the slightest response. Unique case in the annals of our review.
If tomorrow we write an article to explain that the EDF is wasting its time, its energy and the users' money building power lines
high voltage while an engineer succeeded in putting the current in bottles, we would immediately receive a corrigendum to publish explaining to us, either that the process is known but inapplicable, or that it is valid but too expensive, or even that it this is pure fabrication. It would obviously be the same if we were to write that pharmaceutical companies are fooling people since seawater cures everything, or that it is ridiculous to build 4-wheeled cars when with two caterpillars it would be so better.
With nuclear physics, which nevertheless mobilizes time, energy and taxpayers' money, none of this. Apparently, no one dares to reply to Pr. Vallée; for finally, the synergetic theory opens up such vast perspectives, in such a simple mathematical framework, that it deserves to be taken into consideration. Or it is true, and it must be said, and all nuclear programs modified accordingly; or it is false, and it must be proven. This is no doubt where the difficulties begin: to prove that a theory is inaccurate or erroneous, one must already take the trouble to study it, and, moreover, possess the knowledge necessary for this critical study. . The silence that surrounds this theory can therefore only be explained in two ways: or those responsible for fundamental research do not even bother to study synergetics, and they fail in their mission; or they do not have the required knowledge, and that is even more serious.
What makes it difficult to accept is that Prof. Vallée's theory is known in high-level scientific circles; Of course, she meets sympathizers there. Apparently, she does not meet the slightest opponent since no one has dared to officially declare that this theory was inaccurate, false, tainted with contradictions or even completely absurd. It is true that whoever wrote this to us would have to prove it, so would have to discuss the problem with Pr. Vallée.
And it must be said that the latter is a formidable rhetorician, who has already turned over certain adversaries, yet of the highest level, if only about the paradoxes of general relativity. We understand better then why no one dares to contradict it anymore, but obviously this tarnishes the beautiful image that official science wants to give of itself. His silence is no longer that of indifference, but that of embarrassment and a certain lack of courage: if after all Vallée was right, as experience seems to prove, what would we say after the fact of his opponents?
We are therefore going to begin by recalling the basics of synergetics, before seeing the astonishing perspectives that it opens up to the problem of energy. At the start, the principle of coherence which is stated as follows: all the phenomena of nature likely to be apprehended experimentally in the universe are coherent; which means that they all depend, more or less closely and through more or less
less complex, each other manifesting itself, each, as the local result of a universal dynamic. They cannot therefore, in any case, in space and in time, be in contradiction with the state of the universe such as it must be at this place and at this instant.
This statement makes it possible to clearly distinguish a physical phenomenon from any mathematical model that can be given of it. One can, in fact, represent the laws which govern the known physical phenomena only by mathematical expressions of equivalence, within the limits allowed by the measurements, while trying as much as possible to reduce them to simple implicit functions where cannot appear only quantitatively defined, effectively measurable and physically reproducible parameters. In principle, the progress results, when the experimental results require it, by the addition of a certain number of new parameters, necessary for a more exact and finer expression of the laws described. Science would move towards more complexity, a thesis that opposes the search for unity.
The synergetic theory achieves the synthesis between these two opposing tendencies by introducing — and this follows from the principle of coherence — the quantitatively defined notion of synergy, thus extending the principle of conservation to open systems. We are going to summarize this notion quite briefly, because its complete description requires a good knowledge of electromagnetism. This time, we cannot even refer our competent readers to Pr. Vallée's work, because it is currently out of print.
Here then is the restricted statement: Any physical phenomenon can be considered in isolation as resulting from the interaction of two energetic media thus defined: one of these media localized in space and in time can, quantitatively, be expressed by an equivalent mass m, called Maupertuisian mass, associated with the limited domain where the manifestation of the phenomenon studied is circumscribed; the other medium, linked to the physical space of reference, which consequently contains the phenomenon itself, can be defined, in its global interaction with the medium of mass m, by the synergetic potential c2, square of the speed of the light in the reference medium.
The total energy S, or synergy (since it takes into account all the energies), which can be associated with the phenomenon studied is then given, by the fundamental relation of the synergetic theory (established in 1905 by Einstein, but unfortunately reduced to a narrow concept of energy equivalence of matter). S = mc2. The speed of light therefore characterizes the physical reference medium; it cannot consequently, being linked to a potential of interaction, represent an invariant a universal in spite of very weak variations which escape, in the majority of the cases, with the precision of our measuring devices.
The void is full of energy
To return to diagrams that are easier to grasp, the synergistic hypothesis leads to considering physical space as a substrate made up of electromagnetic vibrations, in the sense of Maxwell, forming the frame of the non-material universe; which amounts to saying that each wave propagates in a non-material medium constituted by all the others and which, by the very logic of things, is eternal. To all of these diffuse cosmic waves which make up the medium, must correspond a considerable energy density. Thanks to the calculation made possible by the Newtonian approximation, it is in fact possible to determine a difference of 16,000 kWh in a volume of 1 m3, empty of matter, taken from the surface of the earth and the same volume belonging to interstellar space near our solar system.
Let us mention that these radiations which constitute the energy of iffuse are of very short wavelength (2 to 3 times 1014GHz) and that matter originates within the diffuse cosmic medium when the electric field, randomly due to its statistical fluctuations, reaches the limiting value of 38.67 V/m. Matter is therefore only diffuse energy locally trapped and maintained in this form by a phenomenon of resonance with the free diffuse energy. This cannot therefore grow indefinitely at any point in space, the creation of matter playing the role of energy regulator.
The interaction between matter and energy was known from relativity, but it finds there a much more satisfactory explanation. First of all, the void, in the geometric sense, does not exist; it is just a convenient concept in mathematics. In reality, all of space is constantly traversed by a rain of radiation coming from all directions and carrying much more energy than solar radiation, although being fundamentally of the same nature, i.e. say magnetic elect.
We know that a wave is characterized by two parameters: its amplitude and its frequency. For example sound waves are strong or weak, low or high pitched; the waves of the diffuse energy are also more or less strong, certain frequencies transporting more energy than others, and it is interesting to draw the curve indicating the quantity of energy transported for each frequency. Just as we could, for example, play all the notes of a piano together, but not all at the same strength, and we would draw the curve giving the sound power for each note, that is to say each
frequency. And when we plot the diffuse energy distribution curve, we obtain a mountainous profile whose highest peaks correspond to the frequencies of the neutron or the proton, the two most massive elementary particles. There is nothing surprising in this since, as we have said, matter remains in this form only by resonance with certain frequencies of the diffuse energy; the two most energetic frequencies therefore ensure the cohesion of the two heaviest fundamental particles. The electron and the deuteron (a proton, a neutron, forming the nucleus of deuterium) correspond to two other peaks of the curve, of which all the other peaks ensure the cohesion of the increasingly heavy nuclei. But these peaks of the curve are less and less high as the frequencies increase,
The stability of an atomic nucleus is therefore linked to the more or less intense electromagnetic interactions between the frequency proper to this nucleus and that of the corresponding diffuse energy. However, the agitation of the diffuse medium during its statistical fluctuations, can cause a nucleus to pass from one state of resonance to another by releasing energy in the passage in electromagnetic form in the form of a particle, or in both forms. at a time. This suggests a possibility of direct use of diffuse gravitational energy, the available reserves of which are quite simply inexhaustible.
To pump a little in these reserves, it appears that nuclear reactions involving β radioactivity seem the most suitable. Energy considerations indeed show that during a β decay, it is the diffuse medium that does the work. The key to the whole energy extraction set lies in the reconstitution of a rad ioactive β element. According to the chart of half decay times and energies released by disintegration of elements and isotopes, carbon 12 appears among the basic elements one of the most interesting since its isobaric (same weight of the nucleus) boron 12 gives β energies of 10 MeV on average. In more classic terms, with an efficiency coefficient t of 10-5 (1 atom out of 100,000 in reaction) and an overall yield of 20%, the continuous reconstitution of carbon-12 by disintegration of boron-12 provides 8 kW per gram. Twenty grams would therefore provide 160 kW, or 217 horsepower, which is the power of a Porsche Carrera.
By making this montage, the Belgian Eric d'Hoker proved that it was possible to draw energy from this unlimited reservoir constituted by the electromagnetic waves of the universe. He thus paved the way for synergistic generators, veritable inexhaustible high-power batteries. In the device shown here, current from a battery charges a capacitor, which is then discharged through graphite sealed in the glass between 2 iron electrodes. In the absence of current in the orientation winding, only the energy sent to the primary is collected at the secondary, minus the usual losses, ie approximately 1/2 CV2. If we raise the current in the winding with the rheostat, we note from a certain threshold that the current collected by the vanometer gal is 4 times stronger, i.e. t 2 CV2. This additional power comes from the diffuse medium from which the energy has been taken through the carbon, as predicted by the synergetic theory. The counter-experiment made by replacing the carbon with another conductive element no longer shows the slightest multiplication of power at the secondary.
IMPORTANT: the assembly presented here has never had the approval of RL Vallée. We can refer to the experiments of JL Naudin carried out in February 2005 cf. http://www.jlnlabs.org
It is therefore carbon that was chosen for the first synergetic generator designed by the Belgian E. d'Hoker. How to produce boron 12 from carbon? By a simple reaction predicted by theory and confirmed by controlled nuclear fusion tests; we have already treated the subject (January 1975). Normally free electrons within matter are attracted to positive nuclei and tend to orbit around them; in classical physics, this is their only possible behavior.
On the other hand, we demonstrate in synergetics that we can achieve something much more interesting: to make the electron fall back on the nucleus through intense magnetic fields, parallel and in the opposite direction to electric fields. This fallout of electrons on the carbon-12 nucleus transforms it into boron-12, radioactive, which returns to the carbon-12 state by releasing part of the diffused energy collected in the medium by the radio activity β. It remains to extract this β energy in a practical form. We know, since the work of Lee and Yang, that the β emission takes place in a preferential direction, that of the
magnetic field. The additional current thus created can be used by the Joule effect, or even better by braking the electrons in a secondary winding which will directly supply an alternating current.
The experiment carried out in Belgium was intended to verify this pattern; an electrical capacitor was charged by a battery and then
discharged through a short carbon stick
— in the form of graphite. This first circuit constituting the primary of a conventional transformer whose secondary was connected to a ballistic galvanometer. In addition, the graphite was housed in a winding intended to create the magnetic field in the same direction as the electric field. In the absence of current in this rolling up one recovered with the secondary the energy launched in carbon, with per-your usual specific to any transformer. On the other hand, by also sending the current in the winding surrounding the carbon, therefore by creating the necessary magnetic field according to the theory, we modify the power received at the secondary by a factor of 4. We therefore receive 4 times more power. 'energy
that we put at the entrance, the diffuse medium being of course at the origin of this multiplication of the watts.
For the moment, it is only a laboratory machine of reduced power; but it contains the whole principle of a generator pumping the diffuse energy that surrounds us. It suffices to take from the secondary the current necessary to maintain the reaction in the carbon and we will have an eternal electric generator whose only cost will be that of its construction: coal, copper wire and iron; add a simple electronic assembly to control the input current and that necessary for the supply field so as to obtain the desired frequency; and that's all.
There is even an even simpler experiment, but one that Pr. Vallée advises against to laymen because it risks being as random as touching a small mixture of glycerin, nitric acid and sulfuric acid in the room. Here it is: take a stick of carbon like there is in any ordinary round battery and plug it at both ends into the current outlet, interposing a light bulb on the circuit to make resistance. Make a winding of conductive wire around the carbon and also connect it to the current outlet by interposing a mounting such that the magnetic field created by the winding is in phase, but opposite, to the electric field. If we just hit the right va lu u rs of the electric field or magnetic field, we will collect the modest power of 8 kW per gram of carbon e ,
It is therefore an experiment to be attempted with certain precautions, because if it is in principle exactly similar to the Belgian experience, amplifying the power of the 220 V sector a hundred times risks creating surprises. So let's stay for the moment with the small experimental generator, seeing in it the beginning of the greatest revolution of the century; energy independence. It will indeed be enough at the individual level, to have a modest 100 kW generator to provide lighting and heating for an entire house. The same generator will suffice to drive any large car well beyond 130 km/ h. Farewell oil, coal, uranium and waterfalls; farewell also to immense fortunes and colossal profits. So, ultimately, who slows down the diffusion of synergetic energy?
POWER SYNERGETICS FOR ADVISED DIYERS
It is an easy assembly to make: a stick of carbon taken from a round battery is connected to the sector by interposing a bulb which serves as a resistor. Around the carbon, a copper wire winding also connected to the mains through a D assembly which ensures the phase opposition of the magnetic field thus created and the electric field in the graphite. If the electric field/magnetic field pair is well chosen, the power taken from the mains is multiplied at least a hundred times. To be handled, therefore, with care, chance can do too well
things.
Renaud de la TAILLE-
3rd edit
From Lanca
Hello Chet !
https://www.buch-der-synergie.de/index_englisch.html[/size]and https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=11&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900215&CC=DE&NR=3826970A1&KC=A1#
Synergy means coupling from forces their energy to ' combinated force field ' to an Axis XYZ-ZP : centre
wmbr
OCWL
End quote
Respectfully shared
Chet K
Thanks Grandma
NickZ
  Ramset:  This could be your chance at showing how well this method work. And save the world...
   "POWER SYNERGETICS FOR ADVISED DIYERS
things.
Renaud de la TAILLE-                               end quote.
   "Power from the mains is multiplied at least a hundred times".
    Wow, a hundred times Chet.
    Sure!  Let see it... just wrap a wire around a carbon core, and presto, Magic!
   NickZ
