Free Energy RANT CAFFE ASYLUM
Started by v8karlo, October 02, 2020, 03:11:51 PM
AlienGrey
Quote from: AlienGrey on November 20, 2022, 09:29:18 AM
Nick no offence intended but are you the Margery Proops critic or a electronics builder with your years of experience of  Research and development you keep quoting you have.
You realy need to make your mind up or we will never get any where if we dither back bite like Verpies's comment.
Can i suggest you look up how push pull is defined as compared to single ended.
https://en.wikipedia.org/wiki/Push%E2%80%93pull_output
Sil
Nick what I am saying is, I am repeating what Ruslan Akula and Edward Grey all said separating the positive
a sign wave does not do that, you said a good few pages back on the Dally thread your katcher produced a sine wave!
Is that clear enough for you ?
Sil
NickZ
  AG:
  Show me a single scope shot of a HV, HF output showing a DC signal coming from a Kacher/Tesla coil circuit.Which allows to self runs the device.
   I'll tell you right now, you won't find any.
   NickZ
AlienGrey
have you tried using an old tv lopt and pulsing it Ruslan does just that in one of his video's
also there is a video where Peter Linderman shows a video at a convention where he has a spark plug
and it's being pulsed by a circuit, he then puts a string of a few diodes across the eht out put the spark
is then different more controlled and far stronger and one polarity. I wonder if how long the thing lasts
before it over heats and some thing blows.
Just using a scope in an E filed is dangerous it produces a strong magnetic pulse it will charge up statically
any metalwork around including the iron in your blood, be aware and experiment with low power and love voltages.
no screen will protect you from this type of radiation.
NickZ
   I don 't have any health problems due to my device. I have probably spent more time working and tuning on it than any one has. As Tesla said, it depends on the frequencies. As I've mentioned, transistors, and mosfets  do get hot. As well as the coils.So following the schematic does not mean that everything is right with the Ruslan/ Stalker devices and their replications and diagrams.  Still no one is using them, instead of the grid. So, much  more fine tuning is needed, even before they can selfrun for any use able amount of time., or they will heat up, and melt something. I have done overnight runs and heat tests on it, also.
   NickZ
   PS.   Itsu: Nice to see you, "still trying to crack this nut". I still have mine on the bench. Getting a bit dusty, and rusty, but there's still hope...  I think that we have all misunderstood about needing to use a Kacher with  DC output pulses. Simple Kacher worked for Ruslan, Stalker, and Adrian even in the outdoors field tests. While the controllable Kacher has not helped any of those of us that have built it. Showing even less output, than the simple Kacher, so something is not right there. And I am still trying to find a solution.  I do like how there are more focused threads to work with at the other forums.Less distractions,  less rants, and  more honest and current tests results, etc.
    NickZ
forest
Ok, now please explain how to get Kacher output DC pulses ? How to build Kacher to mimic Tesla disruptive discharge ? How to get Kacher with LC tank circuit and get current inside LC tank circuit many times the input current. I'm sure this is what is needed.
