AC voltage from single magnetic pole
Started by nix85, October 04, 2020, 10:16:36 PM
nix85
As you say yourself it's due to shadowing, when current coil is facing the driving coil, voltage coil sees flux from current coil only, ofc they are gonna be in phase.
nix85
I would appreciate someone comment on this Zimbabwe guy, what do you think he is doing, probably along the lines of Don Smith and James Schwartz. He is calling his generator "Sonic" implying sound.
NdaClouDzzz
Quote from: nix85 on October 13, 2020, 09:55:20 AM
Greetings, nix85
It's hard to tell because as you point out "he keeps the principle tightly secret...."
His devices "harness radio frequencies...the microsonic energy device which is the main part of the machine, the one that harnesses [the] radio frequency [and] convert it into DC current...in the DC current we've got what we call a down converter (DC-DC step-down converter)...." https://youtu.be/NHePKrB__RM?t=1167
It sounds to me like he is using the concept of a particle collider ( WTF is a particle collider? https://techcrunch.com/2017/07/05/wtf-is-a-particle-collider/ ), only using radio frequencies instead.
If we look at this ad for Microsonic Earplugs ( https://pro.ultimateears.com/products/microsonic-earplugs ) it says that they "reduce all frequencies". What are we doing when we "reduce" a frequency? Slow it down? Turn it into a lower frequency?
The energy device inventor recognizes that there is very little energy in radio frequencies ( "...radio frequencies are usually measured in micro(?), very little energy...." https://youtu.be/NHePKrB__RM?t=1116 ). Yet he is using those low-energy radio waves in a way that turns them into usable power.
My take: Two equal radio frequencies going in opposite sides of a coil and colliding in the middle should not only lower (reduce) the frequency, but also increase the amplitude of the wave, thus increasing the power.
Of course, he could also be using Heterodyning ( "A heterodyne is a signal frequency that is created by combining or mixing two other frequencies using a signal processing technique called heterodyning...Heterodyning is used to shift one frequency range into another, new frequency range, and is also involved in the processes of modulation and demodulation. The two input frequencies are combined in a nonlinear signal-processing device such as a vacuum tube, transistor, or diode, usually called a mixer. A major application of the heterodyne process is in the superheterodyne radio receiver circuit, which is used in virtually all modern radio receivers".  https://en.wikipedia.org/wiki/Heterodyne  https://en.wikipedia.org/wiki/Superheterodyne_receiver )( Idea about Heterodyning came from Zed at the Don Smith forum discussing Don Smith's use of radio frequencies ).
And of course, the inventor of this energy device could also be employing Rectenna tech. In fact, He uses similar language found in a Rectenna article.
Inventor Here: "I think this is something that Nikol[a] Tesla saves(?) when he started the journey of trying to transmit electric using radio frequency. In that time people thought maybe he was crazy or something. I'm happy that He
saves(?)...that was ahead of his time, that time. So I would want to believe that we have managed to accomplish the work that He started back then".  https://youtu.be/NHePKrB__RM?t=1076
Rectenna article: "Envisioned by Nikola Tesla, wireless energy transmission was made possible in the 1960s with the invention of the rectenna".  https://www.ece.cmu.edu/news-and-events/story/2019/05/rectennas-converting-radio-waves-into-electricity.html
Rectenna https://en.wikipedia.org/wiki/Rectenna
Cheers
nix85
Ofc he is not using low-energy radio waves or radio waves of any kind except probably as excitation.
He is converting higher order energy into electricity just like many others did/do.
Key is probably resonance, i never saw the back of his device, i guess i would see plates like James Schwartz uses, basically bismuth aluminum caps with fine wire coils inbetween or similar.
Remember Schwartz said he is feeding multiple frequencies at once, these frequencies might be location dependent as we see in his 6kW device from ~2009 that he first finds a local frequency unless that is a sham like "73-74 element" rods he lied about.
Probably resonant + harmonics, God knows, delicate stuff.
nix85
Most people here have not yet recognized the IMMENSE value of the paper HARNESSING THE FORCE OF GRAVITY, written by the son of great Edgard Hollingshead summerizing his father's work in just 8 pages of pure TRUTH.
His father developed a ray machine that basically used disruptive discharges that could vaporize matter into nothing or make aluminum 20% lighter etc, he only said he built up atomic speed (voltage) and then released it suddenly, disruptive discharges ala Tesla and others.
He proposes the most valid and most simple theory of gravity which perfectly aligns with that revealed in occult book Dweller on two planets, this is science of Atlantis, the SAME model from 13,000 years ago. Negative gravity is here, it's just that we provide no resistance to it unless we speed up a little.
http://svpwiki.com/pdffiles/hollingshead-original.pdf
