Капанадзе
Started by justawatt, October 20, 2020, 03:25:53 PM
Void
niyazzi
And more. Bunk has a partner with the nickname Googlodrom.They did the installation together. He was banned from u-tube a long time ago.He doesn't make any more videos. It is possible that his old videos related to the Kapanadze installation may have been saved on your resource. I think these videos would be useful. Recently Googlodrom said that they gave the scheme on one of the foreign sites.And someone repeated their installation. If this is true, it would be easier for you to find this information because I do not know any foreign sites dealing with the topic of Kapanadze.
justawatt
Jeg
Hi guys
I watched carefully all of their videos having only one thing in mind.
And there is no moment even for one second that they show us the back side of the big pipe coil. It is supposed that the two thick coils are connected together at the back of the coil, but really the inventors are hiding this connection very carefully. It makes you wonder...
If justawatt is right and i believe he is right, the long coil is seperated in to two parts. The end of each part might connects itself to the end of each of the thicker coils.
During the last years i have seen some devices that utilize two Tesla coils, one being 1/4 of the wave, the other being the 1/2 of the wave. That means that the 1/4 gives an antinode at its end (high voltage), and the other gives a node (high current). If a load is connected in between, it takes the same time a High voltage peak along with a high current peak. (think Tesla's fireballs).
r2fpl
Quote from: niyazzi on October 23, 2020, 03:59:40 PM
I'm trying to upload an archived video, but I can't. https://cloud.mail.ru/stock/3Hi8FKBC6k66vyADq3NU4Vf4
What is the question.
1. The kettle with water cannot be moved so it can be connected under the table.
2.LED? the heater may not work at all and only the LED is on
3.Radio - why is everything working? there should be interference.
4. When the hand touches the coil also there should be interference and it should affect the current output. However, we do not know the operating frequency of the device and it may be immune to interference.
I've seen videos and there is something on each that shows a hidden wire. Bunk holds the device and the bulb is lit - yes, but there may be an electric wire in the sleeve of his jacket. You can't see anything in the saw with the saw.
Everything is not very clear but it is actually very simple and maybe nobody understands it.
The device should generate HF and act as a stepdown transformer. If anyone has a different opinion please show me.
At no time can I see the light bulbs (heater). They should light up because it turns off the heater for a while and reconnects it. Maybe you can't see well or they are broken. Both? He repeats that the radiator gives off heat, but this information is not reliable for us.
The gentlemen are probably making jokes and having fun.
