Капанадзе
Started by justawatt, October 20, 2020, 03:25:53 PM
NdaClouDzzz
"This demo is done with FLY POWER. It is colliding STATIC and DC and forcing their collision to a common ground.
Static = HV electrostatic potential with virtually no current.
DC = Lower voltage with some actual current".  https://youtu.be/azfxP9lBAao?t=24
NickZ
     Guys:
   I don't know if it has been mentioned, but, there is NO Earth ground connection needed nor used on  the single tube model, nor on the bigger double tube device. Which also means, that there is NO extra current coming into the device from any earth ground connection. And so, if it works as shown, any extra juice would have to come from the surrounding ambient.
   Remember that Tesla had the first patent on a UFO craft. Which also probably needed no Earth ground connection, to operate.
This is very important, as any mobil devices as well as vehicles can be run off of this type of device, without it needing to be directly grounded by a wired connection. I feel that this is a step in the right direction. And probably does work similar, if not the same as the Roma device, which has also not been heard from, lately.
   NickZ
   PS. Thanks for the new link, itsu... good to see you here.
Void
Quote from: Jeg on October 26, 2020, 12:56:17 PM
Hi Void
I have seen this again and indeed blindly replicating is the worst thing an experimenter can do. But it is not a new idea. Bringing voltage in phase with current across a load, is something that many people have talked about. And if this is the case then the range of frequencies that involve is related to what we already know about Tesla coils, sfr, 1/4 etc.
Hi Jeg. Unless Mr. Bunk provides details about what his output waveform from the
modified electronic ballast driver looks like, then experimenters may have no choice
but to just try different waveforms and frequencies. That usually doesn't go too well however. :)
I am skeptical about this device because really it is just a long air core coil driving the bucking coils
output coil, but I am trying to keep an open mind. Maybe there is some key concept that
we would need to know which makes magic happen. Just the right driver output frequency, or just
the right type of driver output waveform, or both? If Mr. Bunk does not want to show or explain such details,
then it seems very tough to try to replicate. Just my own opinion.
Nick: Yes, it doesn't appear to use any earth ground connection.
Void
This is how I see how Mr. Bunk's earlier (and simpler) 'All In One' circuit is connected together.
This appears to be the heart of the Bunk 'Monster' circuit. If you can't get this simpler circuit arrangement
producing a COP > 1, then it seems doubtful you will get the more complicated 'Monster' circuit working.
If you see something different in how the 'All In One' circuit is connected, let me know.
niyazzi
