Капанадзе
Started by justawatt, October 20, 2020, 03:25:53 PM
Void
Quote from: Jeg on October 28, 2020, 06:13:30 AM
Hi Void
Thanks a lot for your answer. May i ask one more question. Does this 50 ohm load resistor, also contains the reactance of the load or is it just the ohmic part?
Hi Jeg, the calculation was assuming a purely resistive load (no reactance).
If there is some reactance, then you can can potentially get higher voltage swings across the load.
Void
Quote from: r2fpl on October 28, 2020, 03:43:00 AM
I have 100% proof that the FE is there because I did tests that there is voltage and current! All you need is an oscilloscope and a current probe that you surely have.
Hi r2fpl. In a resonant coil with no load attached, you can see large voltage and current swings,
but the voltage and current are out of phase. When you attach a resistive load to the resonant coil,
the resonant voltage and current peaks drop considerably and the voltage and current across the resistor
will be in phase. When the voltage and current are approximately 90 degrees out of phase in a resonant
coil, that is called imaginary power or reactive power. It is not real power. The only actual power being consumed
is due to the resistance in the wire which is used to make the coil. To be able to pull real power off a
resonant coil without destroying the resonance is like trying to find a pot of gold at the end of a rainbow.
Leprechauns like Kapanadze and Akula have claimed to have found that magic pot of gold,  but it remains to
be independently confirmed if they really did achieve that or not. :)
Quote from: pix on October 28, 2020, 04:48:23 AM
@r2fpl
The simplest way to extract energy from Tesla without disturbing resonance is by spark from top terminal. Tariel Kapanadze used it in Turkey demonstration. Movies are on YT. Spark from Tesla top goes to the ground by HV step down air transformer.
Driving Tesla coil- like Tesla said: loose coupling between primary and secondary at the  node ("ground")level, where  the current is.
To make coupling even looser, an extra "third" coil was used.
Hi pix. We have mountains of theories here. The only thing that really counts is if a person
can actually demonstrate that a theory really works with a real circuit demonstration.
Bunk and Gulodrom don't appear to be using natural coil resonance in their circuit, otherwise it seems to
me their circuit would be very sensitive to going 'out of tune' when they placed their hands close to the long coil,
or when they connected different loads to the output coil. Also, I have seen no indications so far that their circuits
are producing high voltages in the kV range. No sign of corona or arcing seen...
NickZ
Quote from: pix on October 28, 2020, 02:24:13 AM
Imagine huge potential difference between Tesla coil top and ground.
Electrons are "sucked" from the ground. It is resonant amplifier that collects energy during every swing. With every push from primary more inertia is building up in secondary, as voltage is rising on Tesla coil top, and current is rising at the ground node. Frequency of pendulum oscillations do not depends from the mass of pendulum.
It is like during every push for mechanical pendulum, mass of the oscillating weight is increasing. You started with, let's say 0,1 kg mass on pendulum, and after some time the swinging mass has 1 kg. Energy is collected in the swinging pendulum, but frequency (resonant) is the same.
Do you see now?
   You guys will never convince me by repeating what you've heard. SHOW ME the FE that you are just talking about. As if I've never heard of it. Words are cheap, and you guys have never ever actually built anything at all that self runs, or even OU.
  So, no I don't SEE anything from you two guys showing us all how well you can build a self running device. Just talk won't cut it.Put your cards on the table. We don't need more theories, even if they are correct, we need self running machines.
   NickZ
NdaClouDzzz
Quote from: Void on October 28, 2020, 09:08:55 AM
To be able to pull real power off a resonant coil without destroying the resonance is like trying to find the pot of gold at the end of a rainbow.
Over 2000 posts and you still continue to deny the obvious. Seems pretty clear why Rick calls you "Void of truth"!
https://youtu.be/0bpv3wUWGqk
https://youtu.be/Vb5bBSGiGvA
https://youtu.be/tpoOWs8SfVo
https://youtu.be/18kOGVfkoik
Void
Quote from: NdaClouDzzz on October 28, 2020, 09:18:13 AM
:o ;D
