Капанадзе
Started by justawatt, October 20, 2020, 03:25:53 PM
sm0ky2
Hard to follow without something on my bench,
But the way i see that, the variable resistor at the base of the first transistor
Controls the base frequency, the power through that is then amplified by the inductor
And the mosfet
Then sent through the full wave rectifier and added in at the 1/4-wavelength
(given some discrepancies about the speed of light and conductivity of copper)
this is a resonant amplification (in-phase)
Then the frequency is multiplied 4 times to the output,
Probably not "ou", because these electrons are all coming from a common ground.
But very interesting circuit
seychelles
worldcup
@sm0ky2
Is there a way to simulate this!
AlienGrey
worldcup
More secret revealed from -david-
The inside is filled with iron filings grains
1/4 of pipe is with thin copper sheet  .
in pic,electrode is center tapped wire connected to copper sheet, this black wire comes from center of kapa coil in 1st pic of green box from left.
copper sheet not full round, but half round
device works with 2 mixed AM frequencies and static pumping is stored in capacitors and later to load,something along those words as i remember.
Its very simple design , he says. spark gap acts as arrestor , it has no actual role in energy generation.
