A Working Radiant Free Energy System
Started by callanan, January 05, 2007, 01:46:30 AM
bolt
I like to see this done with an earth battery. If the circuit needs a dipole we give it a very big one. It will also take the old batteries out of the equation that might be recovering. A copper tube and iron tube should work fine. I cant remember which way round they go but should also line up north and south if you have space. If this makes things look worse then leave the south pole in and make the north pole a small antenna instead. The most serious problem with antenna version is your spark gap turns this into a nasty transmitter.
Resonant
Hi
I also think mosfets would work beter, but all knew igbt's or mosfest come with a freewhel diode.this shorts out all radiant. I'v heard that first mosfets didn't have diodes, i'd like to experiment with them but havent found any yet.
mavinak85
Hello there, I am new to Overunity forums.
Did somebody reproduce this device?
@Ossie: did you finally discover if this was working?
I need some info because I would like to build up one, but I will not start if somebody has already checked that it was not working or that the schematics were wrong
Thanks
mscoffman
Quote from: Resonant on December 09, 2007, 05:44:06 PM
Hi
Static Electricity == Radiant energy
MOSFET's also used to be very sensitive to destruction by static
electricity, MOSFET's have very high impedance and low leakage
that makes high voltage at low currents destructive.... This also
tends to be why modem digital instruments go haywire when
connected to Bedini machines. And also why Bedini machines
seldom contain capacitors as WVDC cannot be exceeded, even
marginally, without damaging them...Ultimately things do make
sense, even if overunity.
:S:MarkSCoffman
the_big_m_in_ok
barbosi said:
...That was the reason to ask if I could measure the joules stored in battery, as a more accurate energy measurement. ...
From my experience in photovoltaic renewable energy research, there a relative problem in determining that:
When two lead acid batteries are discharged, one faster than the other, the slower one discharged will show more storage capacity than the other.
Other types of batteries doing the same thing?
I don't know.  I haven't studied that aspect.
Lead acid types are widely available and commonly used in renewable energy systems.
--Lee
