A Working Radiant Free Energy System
Started by callanan, January 05, 2007, 01:46:30 AM
sinergicus
Hey LEE
The cold electricity will not mess up the battery ;you will destroy the batteries just when you charging them and  using power from them  in the same time.
You must connect the battery to  load when the  battery are not charged and disconnect the load  ,for a fraction of time to dump the capacitor charged by radiant (cold electricity) back in the battery.
The capacitor will transform the radiant energy in usable form, instantaneously  .This is a little complicated ;you need a mechanical or 555 timer to do this periodically (charging capacitor few seconds and after this, dumping the charge, back in battery).
You can also avoid to using capacitors ,and send the radiant energy in a second battery to recharge it,but must wait one or 2 days to let the battery to transform that energy ,in usable form .After this, you can use it ....
ramset
Sinergicus
Thank you for sharing this!
It will be a very good day when we have more understanding as to "why" the system "works" this way!
Learning the "nature" of nature.
Chet
Thanks Grandma
guruji
Quote from: sinergicus link=topic=1868.msg233157#msg233157 A=1268917576
Hey LEE
Hi Sinergicus are you sure that if one charge the battery and use it at the same time one destroys the battery with cold electricity that you've said?
I am asking this cause once bedini said that one can do a bedini to a small solar panel so maybe did he mean to do a switch to this to switch it off when using them?
resonanceman
QuoteJohn Bedini stated somewhere,this is not good for batteries ;to charge them in the same time when consuming power from them...this will destroy the batteries
Are you  sure that this is actually  what  Bedini said?
I have been working  with feeding impulses from JTs back to the   battery for a long time........ I have not seen  any sign of my batterys being  destroyed.
The problem is thatthe driving battery is deleivering regular electricity whereas the charging
battery is receiving radiant - cold - electricity. They don't mix.
can  you define what  radiant energy is?
Are you sure that they don't mix?
Is there ANY proof?
I do remember  a video  where Bedini showed that a battery charged  with what he called Tesla Impulse  Technology would continue  to charge for a while after  removing  the battery from the machine .
The  2 day figure  seem ridiculously high to me.
We  are talking  about  an excess charge of Ions on the plates of the  battery evening  out........I would think that would take  maybe a half  hour at most.
My opinion   is that  a battery is a chemical reaction ......it is relatively slow....... the radiant energy spikes  are almost instantaneous.
It  takes time for the  radiant  charge to sink in.
I also  remember Bedini  saying that  a  radiant pulse is a more efficient  way to  move the  ions in the battery.
It seems to me that if you  try to recharge  the  battery  you are  using to power your  device  you  will end up  mostly  running  off the radiant spikes because  the chemical  process  takes time ........your battery is acting more like a capacitor  than a battery.....simply  storing  the radiant  charge  until you  use it.
I also agree  with  Stephan
The  radiant  impulses will recondition  many  of the so called dead batterys  you might  get  from a recycler..........but this  might not matter........ they still might  serve the same purpose  after they  are reconditioned.
When   talking  about  a 10 coil  bedini  ..........Bedini said this " the more batterys  you connect to this  the machine the more you will  get out of it".
gary
guruji
Hi guys I was reading JB guide and it says that to use an SSG charged battery one has to use an inverter. What type of inverter he's refering to? A 12v to 24v inverter?
I think it has a certain truth in this cause when I tried to use these charged battery the SSG could not run.
Any clue?
