Chinese Oscillator and MOS FET Driver, Hardware experiment
Started by AlienGrey, November 13, 2020, 04:37:08 PM
MasterPlaster
Quote from: Jeg on February 04, 2021, 03:46:55 AM
No, it is 5turns in series but made out of five wires in parallel. Like 5T with very thick cable.
I am having a deja vue.
conico
do not use any capacitor in the oscillator with mje13003 I think it is just astable  oscillator and the capacitors are even in the coils  if you want to have the same frequency as the Chinese type, you must have the coil of 8 turns to be 150uH and the one of 11 turns 250 uH.
So , if you do't have 150 microH on 8 turns make 9 or 10 turns or 7turns. The same on 11 turns , if you don;t have 250uH make 12turns or 13 turns , and is enough to have  the same frequency of the Chinese guy. Do'nt edd a capacitor like in mazilli diagram it will change the frequency dramaticaly.
In the second ferrite transformer you see there are 5 turns from 5 wires but NO is just one turns from 5 wires in parallel.
See mazilli diagrams  where 5 turns is for IRFP 260 with R( DS) on 150 mili ohms but  the the Chinese guy use IRFB 3077 with R (DS) on 3,3 miliohmi. That means he use just one turns. With just one turn you will have more votaje and more amps.
I want to know your opinion please.
Quote from: MasterPlaster on February 04, 2021, 12:37:49 PM
For each amplyfied ampere 1 ampere-coil ?
http://www.intalek.com/Index/Projects/Patents/DE3024814.pdf
To understand the above effect it is important to study Kunels
https://worldwide.espacenet.com/publicationDetails/mosaics?CC=DE&NR=3101918A1&KC=A1&FT=D&ND=3&date=19820819&DB=EPODOC&locale=en_EP#
figure 6,7
and second drawing page figure 18,19
               clearly included the scheme figure explanation in the description part !
B. a relatively small amount of electrical energy is required as an excitation current for the coil winding, or a hand crank is used with which the machine is energized according to the dynamoelek tric principle.
If one assumes an induced value of 100 Gauss for the electromagnetic excitation of the coil winding in the mean cross-sectional diameter of the coil winding without the soft iron core, 90 the nickeling receives an assumed value of the magnetic flux density after the insertion of the indented core according to the schematic representation 1000 gauss. This 1000 Gauss magnetic flux density (field line density) is integrated at the moment of the introduction of the complete current-carrying coil between two field magnetic poles with a magnetic flux of, for example, 5000 Causs and thus added to 6000 Gauss. With the simultaneous flow of the increased flux density through the coil in its longitudinal axis in the same direction of its own magnetic flux, the current voltage in the coil is suddenly increased by this self-induction during the ongoing rehabilitation of the magnetic field in the coil winding between the field magnetic poles. [0018]
This induction increase in the voltage, in turn, retroactively increases the magnetic flux in the coil core and in the entire machine system, possibly by a further 4000 Gauss or more, to a total of 10,000 Gauss (= 1 Tesla).
In this way, the initial value of the magnetic flux density of the value 1 is brought to the value 100, without an additional quantum of electrical energy having to be supplied in the functional sequence. In this way according to the invention a relatively high magnetic flux density is achieved as a result of the installed energy with little energy supplied, with which a very considerable torque can be generated in the machine according to the invention. t) The induction in the present case does not directly cause the torque itself, but it only contributes to the increase and addition of essential forces to a maximum of usable force and thus simultaneously allows permanent magnetic forces to be used and their cumulative integration with electromagnetic forces for conversion into a considerable torque.
What is here the claimed effect ? coil number dependent ?!
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=5&ND=3&adjacent=true&locale=en_EP&FT=D&date=20070201&CC=JP&NR=2007028879A&KC=A#
Jeg
Quote from: conico on February 05, 2021, 08:10:48 AM
Hi conico.
I am talking about the capacitor that the Chineese used across the drains of his mosfets. This is at the second ferrite transformer and not at the oscillator side.
You know that experimentation has no limits. You can test as many turns as you like across your primaries or secondary. But if we are to replicate the effects of the Chineese we have to stick to his circuits. His ferrite core has 5T in series per primary. As i already told you i have seen his movies. By experience i can tell you for sure that one turn primary will lead your mosfets to destruction. We have 24V input over there. Even by using 5T the current is already huge at the input. By using the caps of the chineese you will consume about 10A. If you also experiment with impedance matching, your input current will grow even more. My best output until now takes place with 24A at the input!!!
There are a lot of issues more though. Like for example...have you noticed that the Chineese doesn't use any choke at the input? What about saturation??? Why he doesn't saturate his core with just 5T at his input? His core is without any kind of gap...think about that.
conico
 Jeg,
We haven't seen the Chinese movie you saw, maybe tell us where to find it. I have some pictures and I say what I understand.
IRFB 3077 will not burn with 25 A in the drain because it withstands 129A in the drain.
