perpetual magnetic toy and explanation
Started by glaysonmestre, November 22, 2020, 11:18:02 PM
glaysonmestre
I was thinking of turning things around instead of rotating the round magnets if I rotated the wrist magnets ?
i liked your drawing which soft used?
glaysonmestre
 8) It stopes because the momentum is expended . 8)   #4
        momentum,angular momentum
        velocity,speed
        motionless,rotative,linear
EMF /MMF   .....Motive....     .......Momentum .......                              Curie,Becquerel: NMF decay period,decay
        Physics: ' Ambient' AMF
        MF/sec per Atom
Not ZERO( or : from 0°K+ force field!) but TOTUMENERGY, ( ex/in-)spendere and (re)cupere
totus up to 0°K 'Brownian movement Entrophy TOTPUNKT,density maxime,zero FREIRAUM
tot-al-izer meaning : con-centrator
Physics : Attractor
permanent magnet ,permanent ? Alignment from NS direction,verting the physical magnet position 180°  = SN
How much ' force units' delivers 1 permanent magnet in its conventional 'Weiss Domain' decay life,
How many 'force units' to demagnetizise ( Barkhausen ! Bieleld-Brown) ,basic ferrit and only physical ferrit atoms bonding ,?
PM temperature range by magneic force winning or loosing condition !?
WithWithout radio-active Cobat,Lanthaniden(rare earth minerals) incorporated !?
Hammer-punch,falling to hard ( sounding) floor                  ultra sound treatment
EMF- device : thermopile/array,hot and called tension spread sources,for electro-/iono-/plasmo magnetism
1920/30 microphones/loudspeaker  material : graphit    future graphene-permanent magnets,
metamaterial PM ferrit nitrogen magnesium
Sincerely
Lunkster
As far as the drawings, I use window Paint because I am too cheep to purchase drawing software.
As far as being a human dog, the gentile woman who asked Jesus for a miracle, when she was told that she was a dog,
she said that even the dogs eat the crumbs that fall from the table.  Since I am a hobbyist, I can only look for crumbs
of what the scientists and engineers may have overlooked in their research.
Are going to deprive me for looking for crumbs?
An I hurting someone else for looking for the crumbs?
I have a hard time seeing that when a stationary magnet on a rotor passing a stationary magnet on a stator
as having an offset in the attraction and repulsion forces in order to perform any work.
But this motor design has a flipping magnet in it that moves through a dead zone.
The energy to flip a magnet depends on the energy between the flipping magnet and the
wheel magnets.  So for me, changing the orientation of the flipping magnet can offset the attraction and
reputation forces between the flipping magnet and the wheel magnets.
Now I know that the educated argument is that no matter where the flipping occurs, whether in the strong flux field or
a week field, that it can not produce an over unity device because of the conservation of energy.  THat statement has been proven over and over again and is accepted as if it were a rock that can not be moved.
For me, performing some simple tests can be a learning experience for people like me.
As I see it, Wrong as it may be,  Changing the orientation of the flipping magnet can offset the attraction and repulsion forces depending of the distance and area of the flipping action.  The biggest question I have is does it take more energy to perform the flipping of the magnet, than the offset that has been created by the flipping?  Again, the general rule of conservation of energy can be used against it working.
Now someone has recently said that a permanent magnet attached to a metal plate in the ceiling is performing workin keeping the weight of the magnet attached to the ceiling.  So if a permanent magnet can produce work in that example, then why would it not be possible for the permanent magnet to perform work as it is flipping and at the same time it is flipping, it is moving through different levels of flux field strength while one of those area's is a dead zone.
So can a permanent magnet perform work?
When I built an all permanent magnet motor prototype that does not function was very educational for me.
You can say, And you did not learn enough to stay away from All permanent Magnet Motors?
For me I am mostly working with Magnetic motors that include electromagnets along with permanent magnets.
This oddsets the disappointments in working with all permanent magnet motors, but I will always be thinking
about,  If a permanent magnet can produce work, there must be some crumb that was overlooked that can be found
to be able to use the ability of the permanent magnet to produce work in such a way as to build a self-running device.
It is bad enough to have a scientist or an engineer tell me what a fool I am when I will find out for myself when
I build and test these overunity designs.
This is why I think a true overunity All Permanent Magnet Motor will come from a hobbyist, because
the well educated people are so closed minded from rules that are 100 years old and can never be changed until
someone proves them wrong.
Lunkster
Floor
@Linkster
Quote from Lunkster
"Now someone has recently said that a permanent magnet attached to a metal plate in the ceiling is performing work in keeping the weight of the magnet attached to the ceiling.  "
End of quote
If that magnet were doing work, then so is a large bolder, that some one
has moved to a position high upon a hill.
            But that bolder is not doing work, and neither is the magnet
Work ....  by definition  ....  is when a object is displaced by a force.
See the explanation attached below @  https://overunity.com/16954/magnets-motion-and-measurement/dlattach/attach/174214/
   best wishes
    floor
