Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
Rosphere
Why are you wound this way, little coil, why?
One black semi mobius coil.
"Semi" mobius coil = no mobius cable?
6 AWG.
Six coils.
Three groups of two.
Clock wise from hoop ends:
Orange.  White.  Green.
Alternate winding directions.
Orange Left hand.
Orange Right hand.
White Left hand.
White Right hand.
Green Left hand.
Green Right hand.
All connected in series.
Why the break between Orange and White?
Coil winding lengths appear different.
Coil overlap ratios appear different!
Winding Lengths and Overlap Ratios appear related to color.
Overlap sections at ends of adjacent colors!
Are all colors cut the same length?
Is each coil on a mobius wind???
Why, little coil, why?
giantkiller
In the Stevennew.mp4, Steven is slinging the TPU around with no respect to the horizontal plane and the light does not flicker.
But when he is done with the 4" unit he turns it over. Maybe a mercury switch or in a new horizontal plane.
--giantkiller.
bob.rennips
Below I use the term loosely, wherever you have two sets of coiled wire next to each other that are magnetically coupled (as in the TPU) you have this transformer effect.
The above is what happens when a 'tranformer' goes into saturation.
The blue is the voltage and the red is the current on the primary.
As the voltage rises the transformer goes into saturation. At saturation the primary appears as a short so the current surges because the effective resistance has gone to zero.
What is nice about this peak is that it is a high current peak but without any of the pesky back EMF when you switch a circuit.
Zip several of these waveforms around your coils a few times and combine them together in other 'transformers'...
Tesla created radiant energy using high voltage and high current spikes.
Dansway
Here is my study of firing the control coils in sequence with a ring counter circuit to make a rotating field.
~Dan
Sauron
Quote from: giantkiller on April 24, 2007, 12:24:55 PM
--giantkiller.
But the coil makes a specific sound when he lifts it...
