Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
turbo
Tao's words again:
Lets say Steven put one big stout cable around or in the rings,and all around these he had many many windings. Now, if Steven put into that stout cable a current and before the current could get to the end of the wire, he stopped it's flow abruptly, then perpendicular radiations (the KICKS), the same Tesla observed, would appear and spread from this stout cable, this would cause Tesla'a copper charging effect, which would hit all the other wires in Steven's coils. Now, if Steven wired the coils right and stopped the discharge of the current through the coils he would be able to extract a lot of extra energy from the tap points on the coils.
Stevens awnser:
So Lindsay, this guy definitely has the secret. I do not know if he will be able to duplicate power generation, but he does have the secret.
Grumpy
QuoteThat length does not match any of the 7.8hz harmonics.
What says it has to?
QuoteI didn't try pulsing the collectors though.
Why would you pulse the collectors?
Have you ever tried to just see if you could get "something" with a long spool of wire, say 250 feet or more, run several loops of stout wire through the center and add a 50 or 100 ohm resistor to the loop wire, and then pulse the spool with short DC spikes (say 5mhz or less than 10 ns) and put an analog meter or other device across the loop coil?  This is just a simple depiction of Tesla's RE induction arrangement.  (Keep the two coils separate.)
No control coils, no rotating fields, no bifilar/trifilar coils, no harmonics, no three frequencies, no "kicks", no mixing and mashing, and no BS to taint Tesla's simple statements - stop the impulse before the current forms - RE radiates perpendicular to source wire - induced RE is proportional to voltage drop across gap - and best results are when mass of primary = secondary.
        -Frank Edwards
innovation_station
turbo
that makes good sence  the tap points
AND  if our tap points go to a fast switch then back into the collector humm...
is
Grumpy
@Turbo,
You don't sound like the "Turbo" that was here several months ago that once went by "Marco" -gave a nice lecture about a "bird on a wire".
You're someone else.
Anyway,
When an impulse is first sent down a wire - the current does not start to flow until the electrons have aligned themselves to the potential - this can be slowed down by increasing the resistance of the wire.  Send impulses down the line and the electrons don't know wether to $#!+ or go blind - flipping all over the place - something's got to give.  No current, no magnetic field - electric field is pegged - hey look, torsion field is right there - BAM RE - had to go somewhere or things start coming apart.  Why no impulse reversals? - pushed electrons back - RE won't manifest.
        -Frank Edwards
giantkiller
Quote from: Grumpy on May 09, 2007, 02:45:54 PM
@Turbo,
Everybody here is somebody else now. It has been a tedious journey.
--giantkiller. Just curious: what does the L.M.D under the bird stand for? 50.1000.500? Oh! Also that is not the Sun but an RE burst heading into a tuned coil...
