Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
Cavetronics Labs
Cap discharge "timming" works better then "chips" , because of the cap discharge(the cap moves its "stored energy)  in the system , the cap can store and move the store about , where as the chips can just act as switchs... unless the chip acts as a cap then its not so "waste-full" ....
The same thing applys to coils ,, as coils act like caps to... so what part is going to blow 1st ? the "chips" most likly..
Cavetronics
Jdo300
Hi Rosphere,
Try this Circuit. Each timer has an adjustable delay before it goes low which will allow razor sharp tuning of the phase shift. Each timer would simply have a slightly longer delay before it goes low (slight frequency difference), so that timers 1, 2, and 3 go low one after another.
When the third timer goes low, it triggers the forth timer, which has a set delay to reset the first three timer to begin the process over again. The circuit is logic low through the use of NOT gates.
God Bless,
Jason O
Jdo300
Hi Cavetronics,
Good thought. Ideally, this circuit would be best implemented with a series of blocking oscillators powered with TUBES.
God Bless,
Jason O
Rosphere
bob.rennips
Quote from: Rosphere on May 30, 2007, 06:29:17 PM
Like so?
what software package are you using for modelling the electronics ? (The waveforms look like somethings from a electronics modelling package ?) Thanks. bob
